F4 on adp5966 whirlpool dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum F4 on adp5966 whirlpool dishwasher
Viewing 15 posts - 1 through 15 (of 24 total)
  • #5405
    tripletman
    whats f4 erroe mean on whirlpool adp5966 dishwasher anybody help please.. ty
    #110935
    tripletman
    Re: F4 on adp5966 whirlpool dishwasher
    please help me the dishies are stacking up on the sides and the babeis have no clean bottles….. PLEASE 🙁 🙁
    #110936
    SIOS (The Whirlpool info CD) states F4 is a drain-out failure OR a computer board failure.
    Put up your postcode and someone on here will help you.
    (We’ve got twins and survived – you CAN do it with 3!)
    Tripletman, sorry no-one has answered this as yet but there are Whirlpool guys on here that will respond as soon as they see the message.
    tripletman
    Thanks guys.. my post code is WS2 0NG..
    Look forward to some positive results.. Thanks again guys… 🙂
    #110939
    DentedPorsche
    Hiya, Sorry for not seeing this earlier.
    F4 Draining failure. Drain pump, control board OWI or water indicator defect
    Hope it helps
    #110940
    tripletman
    🙂 Thanks guys for the re-ply but what do i do now????
    #110941
    Had a look on the database and no-one is coming up as “WS”. Might be a case of Yellow Pages on Monday morning – see if anyone has a DASA logo or Fairtrades – usually a guide to a reputable trader. If not – Whirlpool, but might be a bit of a bill.
    If you DO find an independant, tell him to sign up on this site!
    Good luck,
    Penguin.
    #110942
    tripletman
    🙂 Thanks for the info guys.. Would it be possible to fix it myself how do i go about doing that.. 🙂
    #110943
    If it’s a pump blockage tripletman it should be fairly simple to resolve, check the filter as well if there is one as that could possibly throw up the error as well.
    Other than that if you’re unsure I’d recommend that you call in someone that knows the appliance.
    Same machine, same problem. I’ve checked the pump and impeller not blocked. Hose OK, filter clean. I need an engineer.
    Postcode N6 4TJ
    You can E-mail me if you like John.Horton@Blueyonder.co.uk
    #110945
    Re: F4 on similar adp / 6th Sense model DW
    Similar model – one week old. F4 occurs near start of ANY cycle. There are two questions:
    1) is it “normal” to DW to whir for about one minute before calling for water?
    2) after first call for water, 5-10sec delay then F4 raised.
    I’ve checked for filter, blockage, etc and none indicated (we pre-rinse before load … old habits die hard!).
    Any specific diagnostic info would be greatly appreciated.
    #110946
    Dave_Conway
    osorojo wrote:1) is it “normal” to DW to whir for about one minute before calling for water?
    Yes, the drain pump will be the “whirring” making sure no excess water is inside the dishwasher before starting the prgramme.
    osorojo wrote:2) after first call for water, 5-10sec delay then F4 raised.
    There won’t anything specific I’m afraid, fault codes are not meant to be, they are merely there for engineers guidance. They are quite often inconclusive and sometimes innacurate.
    F4 means that the dishwasher isn’t draining basically, which it probably is so there is an error in the water level “reporting” part.
    #110947
    DentedPorsche
    Have had this on few of the newer machines lately. Changing the NTC cured it.
    DP
    #110948
    My dishwasher is also having the same problem (F4), seems like it might be the pump, I can hear the motor come on but no water are being pumped. Postcode is SP10, can someone give me an idea what repairs would cost. Engineer + new parts.
    Thinking of buying a new dishwasher, Hoover, hopefully more reliable then this piece of …………; Hoover is about £250.
