Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › F4 on adp5966 whirlpool dishwasher
- This topic has 23 replies, 9 voices, and was last updated 21 years, 11 months ago by
tripletman.
April 21, 2004 at 10:12 pm #5405
tripletman
Participantwhats f4 erroe mean on whirlpool adp5966 dishwasher anybody help please.. ty
April 22, 2004 at 8:51 pm #110935tripletman
ParticipantRe: F4 on adp5966 whirlpool dishwasher
please help me the dishies are stacking up on the sides and the babeis have no clean bottles….. PLEASE 🙁 🙁
April 22, 2004 at 11:48 pm #110936Penguin45
ParticipantSIOS (The Whirlpool info CD) states F4 is a drain-out failure OR a computer board failure.
Put up your postcode and someone on here will help you.(We’ve got twins and survived – you CAN do it with 3!)
Penguin45.April 22, 2004 at 11:49 pm #110937kwatt
KeymasterTripletman, sorry no-one has answered this as yet but there are Whirlpool guys on here that will respond as soon as they see the message.
April 23, 2004 at 5:22 pm #110938tripletman
Thanks guys.. my post code is WS2 0NG..
Look forward to some positive results.. Thanks again guys… 🙂April 23, 2004 at 8:09 pm #110939DentedPorsche
Hiya, Sorry for not seeing this earlier.
F4 Draining failure. Drain pump, control board OWI or water indicator defect
Hope it helps
April 24, 2004 at 10:05 pm #110940tripletman
🙂 Thanks guys for the re-ply but what do i do now????
April 24, 2004 at 11:30 pm #110941Penguin45
ParticipantHad a look on the database and no-one is coming up as “WS”. Might be a case of Yellow Pages on Monday morning – see if anyone has a DASA logo or Fairtrades – usually a guide to a reputable trader. If not – Whirlpool, but might be a bit of a bill.
If you DO find an independant, tell him to sign up on this site!
Good luck,
Penguin.
April 26, 2004 at 9:11 pm #110942tripletman
🙂 Thanks for the info guys.. Would it be possible to fix it myself how do i go about doing that.. 🙂
April 26, 2004 at 9:59 pm #110943kwatt
KeymasterIf it’s a pump blockage tripletman it should be fairly simple to resolve, check the filter as well if there is one as that could possibly throw up the error as well.
Other than that if you’re unsure I’d recommend that you call in someone that knows the appliance.
July 3, 2004 at 12:34 pm #110944admin
KeymasterRe: F4 on adp5966 whirlpool dishwasher
Same machine, same problem. I’ve checked the pump and impeller not blocked. Hose OK, filter clean. I need an engineer.
Postcode N6 4TJ
You can E-mail me if you like John.Horton@Blueyonder.co.uk
November 5, 2004 at 11:02 am #110945admin
KeymasterRe: F4 on similar adp / 6th Sense model DW
Similar model – one week old. F4 occurs near start of ANY cycle. There are two questions:
1) is it “normal” to DW to whir for about one minute before calling for water?
2) after first call for water, 5-10sec delay then F4 raised.
I’ve checked for filter, blockage, etc and none indicated (we pre-rinse before load … old habits die hard!).
Any specific diagnostic info would be greatly appreciated.
November 5, 2004 at 11:21 am #110946Dave_Conway
ParticipantRe: F4 on similar adp / 6th Sense model DW
osorojo wrote:1) is it “normal” to DW to whir for about one minute before calling for water?
Yes, the drain pump will be the “whirring” making sure no excess water is inside the dishwasher before starting the prgramme.
osorojo wrote:2) after first call for water, 5-10sec delay then F4 raised.
Any specific diagnostic info would be greatly appreciated.There won’t anything specific I’m afraid, fault codes are not meant to be, they are merely there for engineers guidance. They are quite often inconclusive and sometimes innacurate.
F4 means that the dishwasher isn’t draining basically, which it probably is so there is an error in the water level “reporting” part.
November 6, 2004 at 6:17 pm #110947DentedPorsche
Have had this on few of the newer machines lately. Changing the NTC cured it.
DP
December 19, 2004 at 12:42 pm #110948admin
My dishwasher is also having the same problem (F4), seems like it might be the pump, I can hear the motor come on but no water are being pumped. Postcode is SP10, can someone give me an idea what repairs would cost. Engineer + new parts.
Thinking of buying a new dishwasher, Hoover, hopefully more reliable then this piece of …………; Hoover is about £250.
