Fan Oven not heating up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Fan Oven not heating up
Viewing 15 posts - 1 through 15 (of 24 total)
  • #9908
    I have a Diplomat APL 3201 1X. The fan comes on but the oven does not heat up, The grill does heat up and so does the top of the hob. just the oven… I think it could be a heating element, sre these easy to get hold of and replace ?
    #136679
    Re: Fan Oven not heating up
    hi,
    Dave will answer shortley and we can supply the element for you..
    kevin
    #136680
    Dave_Conway
    kheath wrote:Dave will answer shortley
    I will answer Wilbur’s request, who’s Shortley ? 😆
    Anyway, the element is this one in the shop Wilbur:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=308
    Power off before fitting of course :zap:
    #136681
    shortley 😳
    #136682
    Thanks for your help, you’ve saved me loads of time.. definately bookmarking this site.. 😀
    #136683
    I have exactly the same oven with the exact same problem.
    My question is how do I install the new element?
    #136684
    We are not allowed to give specific instructions for a variety of reasons. Plaese check:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4361
    Sufficed to say that removing the rear inner panel of the oven (with the power off) may lead to enlightenment.
    I also have the same oven I think – APL 3301/2 Type B12 according to the sticker – and with the same problem. My question is: how many elements do these ovens have? Although the fan oven’s packed up, we can still use the the oven on the other settings.
    #136686
    Dave_Conway
    teddyb wrote:I also have the same oven I think – APL 3301/2 Type B12 according to the sticker – and with the same problem. My question is: how many elements do these ovens have? Although the fan oven’s packed up, we can still use the the oven on the other settings.
    There are three, the upper twin for grill/static oven, the base also for static cooking and the fan element which is the likely failure in this case.
    Element is here if you need one:
    #136687
    For the second time in under two years the heating element of my NEFF oven B143ONOGB/05 has packed up.
    Is this normal?
    #136688
    Hi Coco,
    Sadly and element is like a light bulb and there’s no guaranteed life span on it really.
    Thanks K.
    Does that explain why most ovens seem to go over 10 years without needing replacement elements?
    Is it anything to do with the quality of the oven?
    I dont want to keep paying out for replacements and labour if my problem boils down to the oven quality.
    Thanks for your advice
    Coco
    #136690
    Dave_Conway
    COCO wrote:For the second time in under two years the heating element of my NEFF oven B143ONOGB/05 has packed up.
    Is this normal?
    It’s not unheard of to be honest, make sure the fan is running correctly as this can cause premature failure.
    If you need the element, it’s here in the shop:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=383
    #136691
    Dave_Conway wrote:
    Is this normal?
    Thanks Dave. Fan seems to be ok, i.e. I hear it whirring away whenever the oven is on and for a while after.
    Do you think premature failure has anything to do with the quality of the appliance?
    I would appreciate your thoughts…
    #136692
    Coco wrote:Do you think premature failure has anything to do with the quality of the appliance?
    Not necessarily, use and mis-use are often a factors to consider as well. Leaving the oven door open for prolonged periods with the fan element glowing merrily in the cavity is one. Blocking the general airflow with unnecessary baking trays and roasting dishes. Even seen some folks putting kitchen foil on the wire shelves……. ❓
    Neff and other German manufacturers were often guilty of fitting elements rated at 200 to 220 volts also. And the voltage standard in the UK being 230 volts meant the element exceeded its wattage rating when higher voltages were applied, causing early failure. 🙁
    The replacement element ( available from Shop@) however has no such worries and may even be of a better quality standard anyway than that of the genuine manufacturers replacement 😉
