Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Fan Oven not heating up
- This topic has 23 replies, 8 voices, and was last updated 20 years, 10 months ago by
admin.
October 15, 2005 at 8:24 pm #136693
christine
ParticipantEven seen some folks putting kitchen foil on the wire shelves…….
Would this cause a failure?
My Smeg UK80MFX has stopped working – no light, no fan, no heat.
What should I check first? I’ve unplugged, reset clock, does not say A for automatic cooking??
October 15, 2005 at 9:37 pm #136694Dave_Conway
ParticipantRe: Fan Oven not heating up
No, the foil wouldn’t normally cause total oven failure, it restricts the air flow around the oven among other things thus reducing the element’s lifespan. But, you would still have the fan etc running if this had happened, just no heat.
If you’re totally sure that the clock is set to manual then it’s engineer time on one of these to be honest.
Check Repairs@ for one 🙂
October 16, 2005 at 4:00 pm #136695christine
Thanks Dave,
I’ve investigated further and posted a new topic regarding switch failure, which I’m sure you’ll see soon!Thanks
October 15, 2006 at 12:49 pm #136696AndrewBarnett
I have a similar problem with a DIPLOMAT APL 3201. The oven isn’t heating and nor id the element for the grill (are they part of one and the same bit?)… do I need a new element or two new ones? Can someone advise me, please, on what I need and where to get them from? Thanks. Andrew
October 15, 2006 at 1:04 pm #136697Penguin45
If the whole thing is dead, it’s more likely that either the clock is not set to manual, or that the safety cut-out has tripped.
Power off, if investigating.
Penguin45.October 15, 2006 at 2:34 pm #136698AndrewBarnett
The fan is turning and the little light is on but there is no heat at all!Andrew
July 17, 2008 at 8:04 pm #136699Thingfish
Many apologies for reviving this long-dead thread, but could you tell me if the fan oven element at the link you mentioned, http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … ement.html, would work in the Diplomat APL 3301/3 as well? I see it listed for the 3201.
Many thanks!
July 17, 2008 at 8:19 pm #136700Penguin45
That is the correct element for your appliance.
July 17, 2008 at 10:24 pm #136701Thingfish
Penguin45 wrote:That is the correct element for your appliance.
Excellent, thankyou very much, Penguin 🙂
