Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Fan Oven not heating up
- This topic has 23 replies, 8 voices, and was last updated 20 years, 10 months ago by
admin.
June 1, 2005 at 6:45 pm #9908
KeymasterI have a Diplomat APL 3201 1X. The fan comes on but the oven does not heat up, The grill does heat up and so does the top of the hob. just the oven… I think it could be a heating element, sre these easy to get hold of and replace ?
June 1, 2005 at 7:56 pm #136679admin
KeymasterRe: Fan Oven not heating up
hi,
Dave will answer shortley and we can supply the element for you..
kevinJune 1, 2005 at 8:46 pm #136680Dave_Conway
ParticipantRe: Fan Oven not heating up
kheath wrote:Dave will answer shortley
I will answer Wilbur’s request, who’s Shortley ? 😆
Anyway, the element is this one in the shop Wilbur:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=308
Power off before fitting of course :zap:
June 1, 2005 at 8:56 pm #136681admin
shortley 😳
June 1, 2005 at 9:45 pm #136682admin
Thanks for your help, you’ve saved me loads of time.. definately bookmarking this site.. 😀
June 11, 2005 at 7:09 pm #136683admin
I have exactly the same oven with the exact same problem.
My question is how do I install the new element?June 11, 2005 at 7:15 pm #136684Penguin45
We are not allowed to give specific instructions for a variety of reasons. Plaese check:
http://www.ukwhitegoods.co.uk/modules.p … pic&t=4361Sufficed to say that removing the rear inner panel of the oven (with the power off) may lead to enlightenment.
Penguin45.July 18, 2005 at 5:43 am #136685admin
I also have the same oven I think – APL 3301/2 Type B12 according to the sticker – and with the same problem. My question is: how many elements do these ovens have? Although the fan oven’s packed up, we can still use the the oven on the other settings.
July 18, 2005 at 8:10 am #136686Dave_Conway
teddyb wrote:I also have the same oven I think – APL 3301/2 Type B12 according to the sticker – and with the same problem. My question is: how many elements do these ovens have? Although the fan oven’s packed up, we can still use the the oven on the other settings.
There are three, the upper twin for grill/static oven, the base also for static cooking and the fan element which is the likely failure in this case.
Element is here if you need one:
July 19, 2005 at 8:53 am #136687admin
For the second time in under two years the heating element of my NEFF oven B143ONOGB/05 has packed up.
Is this normal?July 19, 2005 at 8:55 am #136688kwatt
KeymasterHi Coco,
Sadly and element is like a light bulb and there’s no guaranteed life span on it really.
July 19, 2005 at 9:07 am #136689admin
Thanks K.
Does that explain why most ovens seem to go over 10 years without needing replacement elements?Is it anything to do with the quality of the oven?
I dont want to keep paying out for replacements and labour if my problem boils down to the oven quality.
Thanks for your advice
Coco
July 19, 2005 at 9:11 am #136690Dave_Conway
COCO wrote:For the second time in under two years the heating element of my NEFF oven B143ONOGB/05 has packed up.
Is this normal?It’s not unheard of to be honest, make sure the fan is running correctly as this can cause premature failure.
If you need the element, it’s here in the shop:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=383
July 19, 2005 at 10:58 am #136691admin
Thanks Dave. Fan seems to be ok, i.e. I hear it whirring away whenever the oven is on and for a while after.
Do you think premature failure has anything to do with the quality of the appliance?
I would appreciate your thoughts…July 19, 2005 at 11:29 am #136692Martin
Coco wrote:Do you think premature failure has anything to do with the quality of the appliance?
Not necessarily, use and mis-use are often a factors to consider as well. Leaving the oven door open for prolonged periods with the fan element glowing merrily in the cavity is one. Blocking the general airflow with unnecessary baking trays and roasting dishes. Even seen some folks putting kitchen foil on the wire shelves……. ❓
Neff and other German manufacturers were often guilty of fitting elements rated at 200 to 220 volts also. And the voltage standard in the UK being 230 volts meant the element exceeded its wattage rating when higher voltages were applied, causing early failure. 🙁
The replacement element ( available from Shop@) however has no such worries and may even be of a better quality standard anyway than that of the genuine manufacturers replacement 😉
