Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › faulty bosch fridge freezer
- This topic has 34 replies, 11 voices, and was last updated 21 years, 6 months ago by
admin.
September 19, 2004 at 9:57 pm #6303
KeymasterCan anyone point me in the right direction?
I’ve got a Bosch Fridge Freezer that’s not playing ball. It’s 6 yrs old – ENR no. is KGV-2604-GB/02.
A week or so ago it stopped working and the temperature in both compartments rose to the point where the freezer thawed. Over the last week or so it’s only come on a couple of times. When it has, the compartments have reached an acceptable working temperature. Each time though, after it has stopped the temperatures come back up and the freezer compartment thaws out.
It’s now been a couple of days since it last came on. Is this a thermostat problem or should I be looking elsewhere?
September 19, 2004 at 11:03 pm #116881Penguin45
ParticipantRob,
dThis is a single compressor fridge freezer, with a digital control board. TBH there are too many variables to give any sort of diagnosis – faults could range from digiboard, thermistors, compressor, start circuits – just about anything.Engineer time I suspect. Check the Directories section for a UKW engineer in your postcode area, or stick it up in here, and someone will pick up on it.
Penguin45.September 19, 2004 at 11:54 pm #116882admin
KeymasterRe: faulty bosch fridge freezer
To Penguin45
Thanks for the tip. I’ll call the cavalry and have someone look at it.
Just for the sake of argument, let’s suppose it’s a compressor problem or any other that you mention. I guess that these are all quite expensive repairs. I know it’s a matter of opinion, money, taste etc. but would I be better off putting the money into a replacement fridge freezer?
Look forward to your reply.
Rob
September 20, 2004 at 12:29 am #116883Penguin45
ParticipantRob,
You can get recon digiboards, thermistors aren’t too dear, compressor job is horrendous!Bear in mind that Bosch gear is upper mid range for quality, so probably worth getting checked out.
Check in Directories to see if there’s a UKW engineer in your area; failing that stick it up in here and someone will pick up on it.Regards,
Penguin45.October 10, 2004 at 9:02 pm #116884admin
Rob
as this has just started to happen with my 6 year old Bosch fridge/freezer I would be interested to know if you had solved the problem with yours
Regards
Tony
October 10, 2004 at 10:38 pm #116885sparkey
ParticipantRe: faulty bosch fridge freezer
Rob,
As posted in another forum the most likely reason for your fault is failure of a foamed in sensor, until recently this has meant scrapping the appliance however Bosch have come up with a repair option that is quick to complete which involves changes to the wiring of the electronic control board, this is not a diy repair I suggest you post up your postcode or look in the directories over to the left for a local engineer.Sparkey
October 18, 2004 at 3:50 pm #116886jcbboy
Sounds like same problem as with the siemens fridge/freezer, they supply a replacement part to overide the built in sensor cost £10-50 inc p+p need to check the bosch website or contact spares hotline, if not in the trade need someone to fit it ,it fits behind the control panel where pcb board is. worth the money to try otherwise scrap the machine if its old, board a bit expensive.
October 18, 2004 at 4:26 pm #116887kwatt
KeymasterBosch/Neff/Siemens, often all the same thing with a different fascia and badge as they are all the same group. 😉
June 3, 2005 at 6:14 pm #116888admin
jcbboy wrote:Sounds like same problem as with the siemens fridge/freezer, they supply a replacement part to overide the built in sensor cost £10-50 inc p+p need to check the bosch website or contact spares hotline, if not in the trade need someone to fit it ,it fits behind the control panel where pcb board is. worth the money to try otherwise scrap the machine if its old, board a bit expensive.
June 3, 2005 at 6:17 pm #116889admin
mine is doing the same I have been told its the pcb that needs replacing £72 did yours get fixed ?
June 5, 2005 at 1:55 pm #116890admin
KeymasterJust Ordered the mod for the PCB cost £12 part 491415 will let you know if it works bosch parts telly 08705543210 .
June 20, 2005 at 8:09 pm #116891admin
KeymasterPart did not work well i say could have done the same with a straight connector , all it does is short out one of the sensores ,been told the PCBs realy go but you can dig out the sensors from the fome in the frigge and replace them for about £15 each
September 11, 2005 at 4:05 pm #116892sharman
ParticipantHi, this topic was a great help, thanks chaps! 😀 I have the same problem with my KGV 2604GB/05. I’ve shorted out the dodgy sensor which has got it working again, but would like to replace the faulty part if poss. I can’t find it listed on the Bosch support site…also, any advice on how to get it out of the foam? whereabouts is it, relative to the control panel? Incidentally, I read somewhere that the working resistance range of these sensor is 10KOhms to 50k. My faulty one reads 100k. 😕
September 11, 2005 at 5:59 pm #116893Penguin45
The whole point of the bypass is that the sensors are foamed into the fridge or freezer insulation and are not replaceable. This is why there is no part number listing.
Penguin45.September 11, 2005 at 10:13 pm #116894Ade
My 6 yr old Bosch FF has just decided to go too! ENR KGU3201GB/01. Can anyone supply the details of an engineer close to postcode ST13 5SB? If so please email beverly.northcott@britannia.co.uk as I can only read this forum until 9am Monday after which time I’ll be away for a couple of days.
Thanks in anticipation.
