Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Fisher & Paykel Smart Drive 708
- This topic has 18 replies, 5 voices, and was last updated 19 years, 2 months ago by
Markaus.
February 9, 2007 at 10:43 pm #24928
Markaus
ParticipantGreetings from Down Under
I have a fisher & Paykel Smart Drive 708.
When I Turn it on it gives 3 beeps and the following lights are on
3rd light from left (group of 8 on top row)
Favourite, Water saver, Warm, High, Hold.I don’t seem to be able to get into the error code function.
Please Help before I use a hammer to fix it.
Mark
February 10, 2007 at 12:43 am #203857Penguin45
ParticipantRe: Fisher & Paykel Smart Drive 708
Haven’t got a clue. Try using the sticky above to work out what’s going on.
Penguin45.February 10, 2007 at 3:15 am #203858Markaus
Thanks for your honesty Penguin45
Could I be in the programing mode for Favouite wash??
(I dont have the user guide anymore to see how to program)After pushing lots of buttons it finally worked but only for 1 wash.
Now back to pushing lots of buttons to make it work again.
This time slowly.
Hope to report back which buttons make it workThanks Mark
February 10, 2007 at 3:29 am #203859Markaus
Further to botton pushing episode.
If I push power or start/pause then the previously posted lights come on
If I push favourite then I get a different sound and is ready to wash, but when I them push the start/pause button to start washing then it turns off.
Hope this info helps
Mark
PS Haven’t got the hammer ready yet!February 10, 2007 at 4:20 am #203860Markaus
Found The Fault!!!
In the touch panel board behind the power switch there was some liquid that had corroded the power switch solder joints. (Dry joint)
Re-soldered the switch and
Hey presto it worked!(The power switch did work. ???? But electronics is a fickle thing)
Thanks Penguin 45
Mark
February 10, 2007 at 7:48 pm #203861Penguin45
Nice one! Good bit of deduction – certainly the symptoms were not logical.
February 10, 2007 at 8:00 pm #203862gegsy
Markaus wrote:(I dont have the user guide anymore to see how to program)
Try here http://www.ukwhitegoods.co.uk/modules.p … ic&t=21910
February 10, 2007 at 9:32 pm #203863Markaus
Bad News
problem has returned
Back to button pushing
Please don’t say new board!
Can’t afford it
MarkFebruary 10, 2007 at 9:48 pm #203864Penguin45
Oh ‘eck…….. I hope Bigsmokepiker wanders in at some point, ‘cos you’ve got me stumped.
February 10, 2007 at 10:00 pm #203865Markaus
The buttons that will make it work are:-
press favorite
press advance 4 to 5 timesThis will work 1 in 10 times
I can not get into fault code thing (your sticky post) to work
therfore I can’t give you the fault code
Mark
February 10, 2007 at 10:26 pm #203866Markaus
More information from the boss (wife)
At the end of the wash it didn’t beep
and it took a long time to stop (brake didn’t work?)
electronics fault still ???
Mark
February 10, 2007 at 10:27 pm #203867Penguin45
Thing is……… If you have to do a force to make it do anything, there may well be some sort of logic problem…….. in the board. Sorry.
February 10, 2007 at 10:33 pm #203868Markaus
Ouch
I will buy a board and see what happens.
thanks for your time
Will keep you informed
Mark
February 11, 2007 at 12:24 am #203869Penguin45
Hang fire for a day or so…… Let BSP have a look at it, he has far more experience than I do.
February 11, 2007 at 1:48 am #203870Markaus
will do
thanks -
