Homark Oven User Manual
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Homark Oven User Manual
Viewing 15 posts - 61 through 75 (of 125 total)
  • #155988
    Charyce
    Re: Homark Oven User Manual
    I also have a Homark oven no manual, no model number and no symbols! Can anyone suggest how I can find a reference of the models so that I can identify mine and then hopefully at least have a picture of where the numbers symbols were or even better where I can get stickers to replace them.
    My oven has a silver door two large round knobs on the right and about 5-6 small black buttons on the left. The first button is the timer, the second not sure, the third seems to stop the timer once it beeps, the last two seem to increase or decreaese the time. There could be one more in there somewhere.
    Dave you seem to know a fair bit about these ovens – can you help in any way? Thank you in advance.
    #155989
    london3r
    Hi, I have a Homark oven. The hob still works and the oven works if its on grill but does not work if the oven is put on. Could you pease tell me how i can fix this? Thank you 🙁
    #155990
    london3r wrote: Could you pease tell me how i can fix this? Thank you 🙁
    Could you tell us the model number of the oven please?
    #155991
    london3r
    I cant see a model name anywhere on the oven. It says Homark Cuisine on it. It is white. In order to look inside you have to open the little door, under which there is the glass panel which you can look through to see the inside of the oven. There is one knob on the left hand side which is the timer. There are 2 knobs on the right. One in the temperature and the other is setting (whether grill, fan etc). I inherited this oven when i purchased my flat 10 years ago. I hope this helps. Any help would be greatly appreciated. Thank you
    #155992
    As per all the other Homark machines, the model number will be on the roof of the oven box. God knows why, but that’s where to look.
    london3r
    I have finally managed to find the model and serial number. The model is 02-7600 and the serial number is J/I310608 and the type is fem 137s. Any help would be greatly appreciated. As i mentioned earlier, the oven works when it is on grill mode but not on oven mode. Thank you
    #155994
    laulz_1982
    I have recently inherited a Homark Oven from a previous owner of our house, unfortunately, the side grids inside the oven have been removed and I don’t have anything that will hold my trays in place. Can you advise if these are available from DIY stores as clone parts or whether I would have to have access to a user manual to establish where I can get these from? I understand that Homark have now gone bust and spares are few and far between.
    Thanks! 😳
    #155995
    Spares for Homark are not a problem – contact spares@ukwhitegoods.co.uk . They will need the model number though.
    london3r
    Penguin45 wrote:Spares for Homark are not a problem – contact spares@ukwhitegoods.co.uk . They will need the model number though.
    Could you please let me know what the problem with my HOmark oven is. Please see my previous posts above. Is it a spare part that i need? If so which one and is it easy to install or is it best done by a professional? Thank you very much for your help.
    #155997
    If the oven does nothing at all – ie, no fan, no heat – the timer probably needs to be set to a “manual” setting. This usually ionvolves getting a “hand” symbol to appear. This article explains the problem more clearly:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=176
    If the fan in the oven is running, but there is no heat, the element may well have failed – check this article for mo9re info:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=103
    Hope that helps,
    dr_skids
    Hi every one,
    as per many other posters here I inherited the oven in the flat when I bought it.
    However, my problem is that the oven just stopped working – I guess it is
    just a fuse (maybe on the oven side as the hob igniters operate okay).
    05-703105A IX B11 is written inside right of door frame. Control layout is Left is a clock/timer with two spring-loaded “knobs”, Right pair of dials
    leftmost is the temperature setting, rightmost is the function setting.
    The oven light has never worked so I need a replacement for that too.
    I have no manual but the oven was fairly easy to work out and has worked fine for last 11 months. 😀
    Clues that it is broken 💡
    The clock would normally operate and make an awful noise but it has stopped. The control lights no longer work. There is no fan operation.
    Where should I look for a line fuse ?
    How does one access the innards of a built-in oven (dismantle it?).
    Cheers for any advice, will be away a few days but not using oven then,
    Dr. Skids 😀
    #155999
    london3r
    Penguin45 wrote:If the oven does nothing at all – ie, no fan, no heat – the timer probably needs to be set to a “manual” setting. This usually ionvolves getting a “hand” symbol to appear. This article explains the problem more clearly:
    Hope that helps,
    Thank you. I will try this out and see if it works.
    #156000
    dr_skids
    Okay so now I am back. Can someone point me to a repair guide?
    Do these ovens have line fuses? What is the best approach to find
    the fault?
    Dr. Skids.
    dr_skids wrote:Hi every one,
    Dr. Skids 😀
    #156001
    Electrical test meter…….. I’ve told you what the forum rules allow. If you’re not sure how to proceed, you must get professional help.
    Check the repairs@ link below for a UKW engineer in your area.
    Forum rules are here:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4361
    peejay
    Just moved and have a homark 02-700301 type e11 cooker but cannot use grill can anyone please help
    many thanks Bob Prettyjohns
