Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover Logic 1200 A3786
- This topic has 55 replies, 5 voices, and was last updated 9 years, 10 months ago by
juicehills.
June 5, 2016 at 4:24 pm #88472
juicehills
ParticipantHi
My trusty old Hoover Logic 1200 A3786 has decided that the motor shouldn’t move when washing or spinning cycle is reached. Could this simply be the carbon brushes?June 5, 2016 at 4:38 pm #438212electrofix
ModeratorRe: Hoover Logic 1200 A3786
very likely common fault
June 5, 2016 at 4:42 pm #438213juicehills
ParticipantRe: Hoover Logic 1200 A3786
Thanks Dave, I’ll check them out.
Colin
June 5, 2016 at 5:06 pm #438214juicehills
They look knackered Dave!
June 5, 2016 at 5:14 pm #438215juicehills
When going into spin cycle, the drum sometimes bangs what sounds like the side of the machine body, although there is no damage. The suspension looks okay, does anyone have any suggestions?
Colin
June 5, 2016 at 6:40 pm #438216Martin
As is always the case the two suspension springs and the metal shaft mounts twist out of shape. The tub then sits slightly at an angle and leans a little to one side. The only cure is to replace both suspension mounts/nylon cups/washers and shaft. Probably obsolete these days and a bitch of a job access wise.
June 5, 2016 at 7:08 pm #438217electrofix
qualtex still showing stock of the pattern suspension kit so can be got
June 6, 2016 at 7:30 am #438218juicehills
Thank very much for your replies, I have been on a bit of a mission to keep this old girl going.
I’ll have a look at those kits Dave.
and I’ll have a closer look at the machine and get an idea of what is involved and how difficult it would be to remove and fit the suspension.
Thanks again for your help gents.
June 6, 2016 at 8:25 am #438219electrofix
suspension kit is a bit of a pig to fit but done lots of them so when your ready will give you a few hints
you will need a Stilton wrench and a 13 mm ring spanner to removeDave
June 6, 2016 at 8:38 am #438220juicehills
Thanks Dave, that would be great.
I had a look at the Qualtex website but I couldn’t find the suspension kit.
I’ll call them later and speak to someone.
June 6, 2016 at 8:51 am #438221electrofix
its a trade only site
i will have a look in work got a sneaking feeling i may have a gen pack still if that fails ask the site shop who may be able to order for you
June 6, 2016 at 11:01 am #438222electrofix
yes got a gen hoover suspension kit if you want it
part no 09049313
do a google image search you will see it
does not come with shafts so they have to be ok
June 6, 2016 at 12:51 pm #438223Andy jones
Yea they are I bit of a pig to fit,
If you take the lid off you can see if the drum is slightly twistedJune 6, 2016 at 1:08 pm #438224juicehills
I did notice yesterday that the white plastic/nylon buts are split!
I’ll take the lid off when I get home and look. Are bolts likely to bend?
June 6, 2016 at 1:10 pm #438225Andy jones
The kit was called an anti twist kit, not sure if it’s still the same
Count you’re knuckles before and after 😉 -
