Hoover Logic 1200 A3786
Viewing 15 posts - 16 through 30 (of 56 total)
  • #438226
    juicehills
    Re: Hoover Logic 1200 A3786
    Dave, I’ll take that kit off you and I can always source the bolts elsewhere if necessary. the site may even have them?
    #438227
    juicehills
    Took the lid off and the drum is decidedly twisted to left hand side!
    #438228
    no probs m8
    will pm you details
    juicehills
    After a bit of a struggle I’ve managed to fit the new anti twist kit and new brushes.
    I have the feeling that I have done something wrong when replacing the brushes.
    Stupidly, I took the old ones out before the new ones arrived, so I may have done something wrong?
    When the machine tries to engage the motor there is a noise like a Drrrrr Drrrr and no sign of life from the motor. There may have been a slight spark around the brushes but it’s difficult to see.
    the drum and motor both turn freely by hand.
    Hopefully, I have just fitted the brushes incorrectly, have any of you experts any suggestions and hopefully just tell me that I have done something daft?
    I wouldn’t like to think it was a bin job after all this work! :eeek:
    #438230
    juicehills
    I checked the new carbon brushes and discovered that one was only just touching the armature and the other wasn’t touching at all. They were a wee bit tight, so I rubbed them down with emery paper and resolved that problem. Armature was a bit grey and manky so I cleaned that. The noise has now gone but the motor will barely turn and smells a bit hot.
    Do you think the motor is knackered?
    #438231
    the wire on the brush where have you put it ?
    a lot of people put it on the field coil by mistake and there is a terminal on the brush holder
    juicehills
    Not sure how to describe it Dave,
    One brush only has one terminal, the other one two that appear to be bridged.
    on that side I have 4 terminals two are occupied and the middle 2 are bridged. I have the brush connected to the right hand one.
    #438233
    no wrong teminal
    look down the side of the metal brush holder
    like here
    juicehills
    I don’t think it’s quite the same, I have attached a photo of the way that I have mine.
    Colin
    #438236
    it is the same thats the field coil and the brushes do not connect there look again at the pictures
    the second picture is just the brush holders
    post a picture of the brush holders
    dave
    #438237
    juicehills
    I had trouble reducing it enough to upload but I think this should be okay
    #438238
    electrofix wrote:it is the same thats the field coil and the brushes do not connect there look again at the pictures
    Oops! 😯
    #438239
    look at where the arrow is pointing and look at the brush ring photo (yours is black but its the same)
    boy have i seen this mistake hundreds of times
    not sure what you mean
    if you mean thats where the brush wire was the answer is no
    also both brushes have to be in the correct position you have only pictures one of them
