Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint Aquarius TCL770 knocking rotating anti clockwise.
- This topic has 19 replies, 4 voices, and was last updated 12 years, 2 months ago by
Goggles.
February 7, 2014 at 8:52 am #79414
Goggles
ParticipantHi, first post hope this is OK.
The dryer appears fine whilst spinning clockwise, as soon as it starts spinning anti clockwise it starts loudly clicking/knocking.
Its the same if hand turned, albeit slower and quieter. There’s isn’t much more resistance felt when turning anti clockwise.
Does this point to anything in particular? If so is it worthwhile replacing or just finding a new dryer?
Many thanks for your time
February 7, 2014 at 9:41 am #409112iadom
ModeratorRe: Hotpoint Aquarius TCL770 knocking rotating anti clockwis
Could be the plastic jockey pulley although as it now only has one pulley it should be noisy in both directions.
Access from right hand side (from front) to inspect.
February 7, 2014 at 11:19 am #409113Goggles
ParticipantRe: Hotpoint Aquarius TCL770 knocking rotating anti clockwis
Many thanks for the reply.
When you say access from the front, do I need to remove the door and front metal casing to do so? Or the lower plastic front where the condenser element fits through?
February 7, 2014 at 11:36 am #409114Andy jones
No the right side as you look at it from the front
February 7, 2014 at 12:41 pm #409115Goggles
Hi, it is the small black jockey pulley, it has a piece missing.
Looks like a fairly easy fix, just a circlip to remove and slide off.
Thanks again for the advice guys.
February 7, 2014 at 1:00 pm #409116iadom
Not that easy, pulley comes complete with mounting.
in fact quite a difficult job if you don’t know what you are doing.February 7, 2014 at 1:42 pm #409117Goggles
ah ok, i just saw the circlip and thought that was it.
can the belt be held out of the way while its swapped? or does it need to be removed in some way?
any other pointers??
thanks again.
February 7, 2014 at 1:47 pm #409118Goggles
also i can’t find the part listed for my machine in the ukwhitegoods store, i’d rather buy from here to give back what i can.
if not will this one do the job?
February 7, 2014 at 2:04 pm #409119Andy jones
That’s the part. It can be tricky. Both fans off. I remove motor 3 of the motor fixing bolts then fit pulley.
February 7, 2014 at 2:13 pm #409120don
Jockey pulley here in the UKW shop.
DonFebruary 7, 2014 at 2:50 pm #409121Goggles
Thanks have ordered from the ukwhitegoods shop.
Is there anywhere I can get a diagram of the motor and if ING points etc that have to be removed?
Not sure how long it’ll take to arrive, the missis isn’t happy without the drier!
February 7, 2014 at 3:28 pm #409122iadom
Andy jones wrote:That’s the part. It can be tricky. Both fans off.
No need to remove the rear fan at all, or loosen any motor screws. 😉
Lie on left hand side, prise off the inner fan housing cover and remove the inner fan, this allows plenty of room to get at the two bolts. Replace pulley and then by whatever means and brute force you can, lever the belt back over the pulley.
Take careful note of which way the belt sits on the pulley as well.
February 7, 2014 at 3:33 pm #409123Andy jones
That’s the way I do it. Dead easy then to get the belt back on
February 7, 2014 at 3:43 pm #409124iadom
It’s just that you mentioned removing ‘both’ fans and loosening motor screws Andy????
February 7, 2014 at 3:54 pm #409125Andy jones
That’s what I meant. I remove both fans just makes it easier to refit belt imo. I suppose we all have different ways
