Hotpoint Aquarius TCL770 knocking rotating anti clockwise.
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint Aquarius TCL770 knocking rotating anti clockwise.
Viewing 15 posts - 1 through 15 (of 20 total)
  • #79414
    Goggles
    Hi, first post hope this is OK.
    The dryer appears fine whilst spinning clockwise, as soon as it starts spinning anti clockwise it starts loudly clicking/knocking.
    Its the same if hand turned, albeit slower and quieter. There’s isn’t much more resistance felt when turning anti clockwise.
    Does this point to anything in particular? If so is it worthwhile replacing or just finding a new dryer?
    Many thanks for your time
    #409112
    Re: Hotpoint Aquarius TCL770 knocking rotating anti clockwis
    Could be the plastic jockey pulley although as it now only has one pulley it should be noisy in both directions.
    Access from right hand side (from front) to inspect.
    #409113
    Goggles
    Many thanks for the reply.
    When you say access from the front, do I need to remove the door and front metal casing to do so? Or the lower plastic front where the condenser element fits through?
    #409114
    Andy jones
    No the right side as you look at it from the front
    #409115
    Goggles
    Hi, it is the small black jockey pulley, it has a piece missing.
    Looks like a fairly easy fix, just a circlip to remove and slide off.
    Thanks again for the advice guys.
    #409116
    Not that easy, pulley comes complete with mounting.
    in fact quite a difficult job if you don’t know what you are doing.
    #409117
    Goggles
    ah ok, i just saw the circlip and thought that was it.
    can the belt be held out of the way while its swapped? or does it need to be removed in some way?
    any other pointers??
    thanks again.
    #409118
    Goggles
    also i can’t find the part listed for my machine in the ukwhitegoods store, i’d rather buy from here to give back what i can.
    if not will this one do the job?
    http://www.ebay.co.uk/itm/HOTPOINT-TDC9 … 3cd148acc3
    #409119
    Andy jones
    That’s the part. It can be tricky. Both fans off. I remove motor 3 of the motor fixing bolts then fit pulley.
    #409120
    don
    Jockey pulley here in the UKW shop.
    Don
    #409121
    Goggles
    Thanks have ordered from the ukwhitegoods shop.
    Is there anywhere I can get a diagram of the motor and if ING points etc that have to be removed?
    Not sure how long it’ll take to arrive, the missis isn’t happy without the drier!
    #409122
    Andy jones wrote:That’s the part. It can be tricky. Both fans off.
    No need to remove the rear fan at all, or loosen any motor screws. 😉
    Lie on left hand side, prise off the inner fan housing cover and remove the inner fan, this allows plenty of room to get at the two bolts. Replace pulley and then by whatever means and brute force you can, lever the belt back over the pulley.
    Take careful note of which way the belt sits on the pulley as well.
    #409123
    Andy jones
    That’s the way I do it. Dead easy then to get the belt back on
    #409124
    It’s just that you mentioned removing ‘both’ fans and loosening motor screws Andy????
    #409125
    Andy jones
    That’s what I meant. I remove both fans just makes it easier to refit belt imo. I suppose we all have different ways
