Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Belt Fitting Tool
- This topic has 46 replies, 21 voices, and was last updated 17 years, 1 month ago by
aqua_serve.
February 28, 2014 at 8:51 am #278447
ModeratorRe: Hotpoint Belt Fitting Tool
HotDog wrote:Could it be the same one i made
Yes it’s the one you made for me several years ago now.
February 28, 2014 at 11:55 am #278448timdowning
ParticipantRe: Hotpoint Belt Fitting Tool
I’m sure, many moons ago when this tool was first mentioned, someone said they just use their hands to pull it over the motor.
February 28, 2014 at 3:12 pm #278449Andy jones
That’s the way I normally do it Tim. Forefingers either side if the motor, thumbs around the belt and lever it on. Honestly never had a problem
February 28, 2014 at 4:42 pm #278450Martin
A 9 rib stretch belt ? Just using thumbs and forefingers? You must be joking surely…..is it April 1st already?
February 28, 2014 at 7:42 pm #278451johnnyj
Martin wrote:
johnnyj wrote:
I have 2 lying in my lockupWould you be willing to part with them?
I could part with 1 i’d like to keep one, might be worth a few bob in years to come as an antiqueMarch 1, 2014 at 6:18 am #278452timdowning
You must have good wrists! 🙂
March 1, 2014 at 11:29 pm #278453A1engineer
i have the tool but prefer using a 13mm nut runner, push through belt and slip motor into runner lever down and twist runner while sliding belt over onto motor.
March 5, 2014 at 9:43 am #278454grooster
Never had a problem using an extra long screwdriver. Stretch the belt down, anchoring the head of the driver under the motor pulley and stretching onto the shaft of the motor that way. Works better with a little WD40 on the length of the screwdriver. Takes 10 seconds.
March 5, 2014 at 3:51 pm #278455alster
The one i struggle with is the condenser dryers with the jockey wheel fixed to the motor,any hints on these would be greatly appreciated !!!
March 5, 2014 at 4:04 pm #278456iadom
There is no easy way, I sometimes fit the belt to the motor shaft then feed it round the drum with the drum to the side and then pull the drum across into position.
March 5, 2014 at 6:02 pm #278457roly16
What amazes me is that anyone would think of designing a belt like this in the first place. It’s not necessary to have it as tight as this as Servis proved when they abolished the jockey pulley in their dryer 30 years ago.
March 5, 2014 at 6:46 pm #278458Martin
……….and Crosslee.
March 5, 2014 at 6:50 pm #278459Martin
Martin wrote:……….and Crosslee.
Mind you Indesit adapted the Creda dryer plant when Creda dryers were at that time a rubbish brand. So Indesit used that technology to turn rubbish into crap.March 5, 2014 at 6:59 pm #278460Simon46
Qualtex QUAMIS182 £9.36 + vat.No problems so far but tool is a bit oily when you get it.
S.March 5, 2014 at 7:15 pm #278461A1engineer
i have a great easy way of doing the condenser dryers, explaining it might be the difficult part but ill give it a go.
fit belt round drum, remove fan assy and remove the bolt nearest you for the jockey, loosen the bolt at the back of the jockey but not all the way, now unhook the jockey and push it away from you as far as it goes, slide the belt into place then grab the wheel of the jockey, pull it back towards you, you will notice there is a lip on the pulley which fits into the motor, once its lined up hook it into motor, refit bolt (sometimes need to move pulley up or down a touch to line up hole) and tighten both bolts
rebuild and test, my record for fitting a new belt is 7 minutes 🙂
Kev.
