Hotpoint BFI 680 Problems
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint BFI 680 Problems
Viewing 15 posts - 1 through 15 (of 18 total)
  • #73937
    Ste3
    Hello, my DW isn’t completing the cycle and would really appreciate some advice. As usual I choose the first program setting from the left, Auto Super Wash. The washer starts but finishes faster than normal, all the items are wet and cold and the tablet doesn’t get released so items remain dirty. Also, the last program (Auto Duo Wash) light is flashing and the only way to get rid of this is to turn the DW off for a few minutes. I am sure that when it worked in the past the light of the program I selected initially would be illuminated after the wash. Seems like it stops mid cycle.
    I have cleaned filters, used a different program and checked that nothing was obstructing the wash blades but with no success.
    How and when do the tablet door open?
    Any advice would be very appreciated. Thanks.
    #389376
    Re: Hotpoint BFI 680 Problems
    The flashing light is an error code, if you have six or seven lights and the last one on the right is flashing that suggests a no heat fault. A very common problem on these Indesit machines.
    The machine needs isolating from the mains, dragging out and then the heating element needs testing with a suitable megger or multimeter.
    If the heater is OK then it’s odds on that the main pcb is at fault.
    #389377
    Ste3
    Thank you for your quick and informative response. I will investigate this further tomorrow and post my results.
    Just for my own knowledge, when and how does the tablet door open on the cycle?
    #389378
    It can depend upon which cycle you select, some programmes include a prewash. In most cases the dispenser is opened shortly after the main wash starts, at about the same time as the heater is switched on.
    #389379
    Ste3
    Update – took DW out today (it’s integrated by the way). Not too sure what tests I could do once it’s disconnected and on its side. Done a continuity test on the heat element and all seemed fine. Is there any thing else I should check for?
    I also opened the front to view the PCB, there was no sign of a fault – What tests can I perform on this as I can’t find a circuit diagram anywhere? Manual isn’t informative enough for this issue.
    As it is, I’m unsure on what step to take now. Hotpoint aren’t helpful at all – minimum £90 call out is their only suggestion.
    Can’t find a replacement PCB for this machine either to gauge I should just give up or persevere.
    Any advice or help is very much appreciated.
    #389380
    If you are certain that the heater is fine then I would bet good money on the pcb being at fault, rare to see any visible damage, just poor quality components. Two different pcb’s used, full serial number needed to identify, both around £70/£75,
    #389381
    Ste3
    SN is 61219 4090 37307150400. hat do you reckon. Thanks again for all your help with this.
    #389382
    The part number is, C00143219.
    #389383
    Ste3
    Thanks, i’ll keep you posted with the results.
    #389384
    Ste3
    Hi, an update on this. I sent the board away for repair. On retry the results seem worse. When the machines starts it almost suddenly stops with the 6th light flashing (glasses). Any idea what this relates to or have I not connected the part correctly
    Apparently the heater part of the board was fixed so want to cover all angles before I go back to the engineer?
    Thanks once again for your help.
    #389385
    That is a thermistor fault, did you locate the thermistor correctly in the door clip?
    #389386
    Ste3
    Thanks for the quick response. I am going to open it back up now (integrated so bit of agro). Not too sure what that is, any further info to assist me. All i done was connect the board on the left side of the door looking at it head on trying to follow pics from when i took it out.
    I’ll feed back soon.
    #389387
    As long as you can switch off the power you don’t need to drag it out. The thermistor is the temp sensor that should be hard wired to the pcb. It slots into a small clip inside the door inner panel.
    #389388
    Ste3
    Is there a way I can upload a pic of what i’m looking at? Or is there a pic on Google which i might recognise?
    #389389
    The thermistor Is the small, whitish thing that is directly attached to the pcb by two, usually black wires, you still have that on yours don’t you?
