Hotpoint BFI62
Viewing 15 posts - 1 through 15 (of 21 total)
  • #36532
    crawshawt
    Hi Folks,
    Got a BFI62 that had the left two lights blinking as an error. Now get a rhythmic ‘hum click’ with no action after filling (only after the water has been taken out ) and otherwise dead. Is it the pump?
    Thanks,
    Tim
    #251383
    Re: Hotpoint BFI62
    A bit of a confusing post, 😉
    Did you cure the 1+2 lights blinking fault ( a pump time out error ) ?
    Does it now drain correctly?
    The bit that is confusing is this
    ‘Now get a rhythmic ‘hum click’ with no action after filling (only after the water has been taken out).’
    Is the ‘hum click’ after filling, or is it after draining. 😕
    If the machine appears to fill correctly and then you get no action but can hear faint humming noise then it sounds as though your main circulation pump is faulty. It could be a capacitor failure or a seized motor.
    crawshawt
    Re: Hotpoint BFI62
    Jim,
    Sorry about the confusion.
    If the machine is empty (i.e. if I turn it over and the water comes out) when the program is set again the ‘hum – click’ starts, the machine fills but after that the machine stops.
    If the machine has water in it all I get is the hum and click and no action.
    The usual draining sound before filling does not take place in either case.
    The left two LEDS were lit when the machine first malfunctioned but now the hum – click just continues without the error lights coming on.
    Hope this is a little better in terms of clarity…
    Thanks for the reply,
    Tim
    #251385
    Re: Hotpoint BFI62
    The first thing to check in that case is the drain pump, this Indesit machine does suffer from pump blockages more than most. Pump access is from underneath, follow the grey plastic pipe inside. Place a few towels on the floor and be sure to pull the mains plug first.
    Usual culprits are chips of glass or crockery, bits of plastic, wood, sweetcorn etc.
    crawshawt
    Re: Hotpoint BFI62
    Jim,
    I’ve had the pump out and although I have not tested it electrically there was no blockage. Has sounded a bit rough recently though.
    Still getting the hum – click but no error lights, however the machine still just fills and then hangs (when the water had been bailed out), humming and clicking.
    I should perhaps have mentioned that I had recently replenished the salt before it started playing up – don’t know whether this is relevant.
    Thanks for the last reply,
    Tim
    #251387
    Re: Hotpoint BFI62
    If it fills and then you hear the humming noise but no wash action then it is possible the main circulation pump has failed.
    If the machine is empty and you start any programme the first thing it should do is switch on the drain pump, if you cannot hear that running smoothly at the start then your problem lies with the drain pump.
    It is possible to check if the main circulation pump will revolve by trying to push the vanes of its internal fan, also check the capacitor.
    This is after all one of Indesit’s finest. :rolls:
    It sounds like decision time, if it is under five years old you do have a parts guarantee, you only have to pay the Indesit Company £90.00, all parts will be free. A circulation pump would cost you about the same without any labour involved.
    You could also buy something better , it won’t be difficult.
    crawshawt
    Re: Hotpoint BFI62
    Thanks Jim,
    I might ring Indesit and see if I am covered. As it does not drain when switched on I guess it might still be the drain pump as opposed to the circulation pump.
    I can’t seem to find the right drain pump to purchase that looks the same, any idea where I would get one from – the ones on UK Whitegoods for example look different and don’t have this model listed.
    Thanks again,
    Tim
    #251389
    Re: Hotpoint BFI62
    Part number of pump is C00090537, an e-mail to spares@ukwhitegoods.co.uk will get you cost and delivery details.
    crawshawt
    Re: Hotpoint BFI62
    Thanks Jim,
    Will let you know how I get on.
    Tim
    #251391
    crawshawt
    Re: Hotpoint BFI62
    Hi Jim,
    Fitted the new drain pump but no joy. Still hum – click and no error lights – does not drain at the start.
    At a loss as to what to do but ring Indesit.
    Tim
    #251392
    Re: Hotpoint BFI62
    If it is under five years old your parts are covered but the labour charge will just under £90.00. 😥
    #251393
    eltel74
    Re: Hotpoint BFI62
    I have the same problem with the humming just after start sequence, jim mentioned check the capacitor how should one do that and what precautions should be taken? also where can i get one?
    I also had first 2 lights flashing, renewed drain pump and a kinked drain hose thought i had sussed it but no now this problem 😡
    want to check the motor and capacitor then its dishwasher heaven for it cos i am miffed.
    all help appreciated
    #251394
    stripey
    Re: Hotpoint BFI62
    Could be the wash motor that is faulty as this is wired in series with the drain pump.
    #251395
    brinzlee
    Re: Hotpoint BFI62
    Have had exactly the same fault on my machine with the first two leds on the left hand side flashing.
    The drain pump starts at the begining of the cycle and drains any exisiting water and then the recirc pump starts after the machine has filled with water but later on in the cycle the machine stops with the same humming noise and click.
    If the capacitor in the recirc pump has failed is this a replaceable part and if not and I have to order a new pump how do you replace the crimped clips around the hoses? Is there a special tool or is it just a jubliee clip in its place having removed the old ones
    Thanks for your help
    #251396
    Re: Hotpoint BFI62
    If you hear a click after the humming then its more likely to be the motor at fault, not the capacitor.
    The clips are bit of a pain and thin jubilee clips are the best solution.
    It has been mentioned on the trade side that Vauxhall dealers stock a range of thin jubilee clips that are ideal but I have had no luck at my local Vauxhall dealers in the past. 😥
