Hotpoint Dishwasher Mod DWF 33
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Dishwasher Mod DWF 33
Viewing 15 posts - 1 through 15 (of 25 total)
  • #21092
    Ashby
    Hi, This dishwasher has a leak underneath the sump. My 1st question is, how the hell do i get into it? i’ve got the sides off ok. how do i get into the base of it? My 2nd question is does anyone have a parts breakdown they could help me with please? much appreciated.
    Thanks.
    Ashby :rolls:
    #189466
    Re: Hotpoint Dishwasher Mod DWF 33
    Its a Bosch, On the face of it difficult to access, but once you have done it a few times not that bad. Some people turn them upside down to effect repairs but that is not the official, or IMHO the best way. You have to remove the door panel, front plinth, top and sides, release the door hinges and cords and lift the door away, unscrew a few bits and bobs in the sump and salt chamber and lift the whole of the inner cabinet off, after removing the screws that hold it to the base. 🙂 The last one I had leaking turned out to be a split heater box, if that is the case with yours, buy the Bosch one it is much cheaper.
    http://tinyurl.com/ekffn
    Ashby
    Hi Jim, Thanks for your reply.I’m not sure where it’s leaking from but i could see it the water dripping from the sump somewhere. The customer was watching everything i was doing. I’ll have another look next week. thanks for your help.
    Ashby 😆
    #189468
    This is one of those jobs on which it is easy to shift that type of customer, just spread all the bits about a bit and stand on their toes once or twice, they should get the message. 😉
    #189469
    Ashby
    Hi Jim, I’ve found that this machine is leaking from the sump seal. I’ve taken it apart but the seal looks ok. After cleaning the seal and putting it back together it still leaks. Any idea of the seal part number please?
    Many Thanks.
    Ashby
    #189470
    1801256, around £15 + vat list price.
    You could order 263102 from Bosch – £7.88 list…….. 😀
    Ashby wrote:I’ve taken it apart but the seal looks ok. After cleaning the seal and putting it back together it still leaks.
    I very much doubt that it’s the seal causing the leak to be honest, but there’s always a first time I suppose? I think it more likely there’s a pin hole or too in the stainless tub running down onto the seal and spilling onto the baseplate?
    #189473
    Ashby
    Thanks, Jim, Chris and Martin. From what i could see it looked as though the water was coming through between the seal and the sump? When i removed the tank the the white and green wires attached to the red float microswitch came off. there’s 3 terminals on the switch. I’m sure it was only the white one attached to the top terminal. Is that correct?
    Thanks chaps.
    Ashby
    #189474
    Switch is normally open, so see which two are made with the switch closed – that’s where the wires go.
    Ashby
    Thanks Chris.
    Much appreciated.
    Ashby
    #189476
    Ashby
    Hi Chris, me again. just dug out a parts diagram. I notice there is a clamp around the top of the seal inside the tank? there wasn’t one inside this machine.Should there be? (Part No 483056)
    Thanks.Ashby
    #189477
    No clamp fitted to any Hotpoint ones that I have seen, 😕
    #189478
    Ashby wrote:I notice there is a clamp around the top of the seal inside the tank?
    There are 2 clamps (triangular white plastic clamps with Torx 20 screw fixings) that hold the tub firmly onto the seal. 😉
    #189479
    I think he means the huge Jubilee clip round the seal that you see on the Bosch versions.
