Hotpoint Dishwasher Mod DWF 33
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Dishwasher Mod DWF 33
Viewing 10 posts - 16 through 25 (of 25 total)
  • #189480
    Re: Hotpoint Dishwasher Mod DWF 33
    Huge jubilee clips on Bosch? Good Lord! 😕 Whatever is Ashby up to? I am intrigued as to where the jubilee clip fits then? 😯
    #189481
    Think I might have been off on one there, Martin…. Makes a change 😀
    I have seen the huge jubilee clips on the slimline version of Bosch produced Hotpoint machines, never seen one on a full size job though.
    #189483
    Heh, heh – thank you, Jim……… Knew I’d seen it……….
    Just done some checking and in fact the large jubilee clip was used on full size machines. Mainly 68**,71***,78** models.
    Part number , 7081709.
    gegsy
    Ashby wrote:Hi Jim, I’ve found that this machine is leaking from the sump seal.
    Have you looked closely for pin holes in stainless steel on area around salt unit inside tank as previously stated by Martin; or the salt unit retainer collar having come loose? Worth a check 😉
    Ashby
    Hi Chaps, thank you all for your suggestions. There is no clamp inside the machine and there isn’t a large jubilee clip around the seal either. It’s leaking between the seal and the sump at the back of the machine. I can see whereabouts it is by removing the inlet valve. The tank itself is ok.
    Thanks again.
    Ashby
    #189487
    Ashby
    Hi All, Does anyone know the part number for a Tank to fit this machine please. DWF 33P/17, 1020 4290 22618 947 0065. and price. The stainless steal tank i’m refering to not the metering tank. or a second hand one? Thanks
    Ashby
    #189488
    A quick look at Partfinder appears to show the tank but no part number either on the diagram or in the parts list. That would suggest that the price would be OTT. not sure if a Bosch one would be available, perhaps P45’s favourite, Granvilles Petro Putty might be suitable for a short term fix.
    #189489
    gegsy
    Sorry Bosch tank not available as a spare 😥
