Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint spray arm fixing nut
- This topic has 19 replies, 3 voices, and was last updated 16 years, 2 months ago by
ukprometheus.
January 18, 2010 at 10:50 am #51710
ukprometheus
Participanti have a hotpoint dishwasher and the upper spray arm fixing nut seal keeps tearing where the basket is pulled in and out, what i am wondering is if there is a modified part i can use and this part only seems to last about 3 months
January 18, 2010 at 11:00 am #309052January 18, 2010 at 11:40 am #309053ukprometheus
ParticipantJanuary 18, 2010 at 4:58 pm #309054spanishwhite
ParticipantRe: hotpoint spray arm fixing nut
Press your cursor on the word cough and it will give you a link as to what is needed.Without the model n0 etc the guys will have no chance in trying to help you.
January 18, 2010 at 5:11 pm #309055iadom
ModeratorRe: hotpoint spray arm fixing nut
ukprometheus wrote:
sorry fella did i miss something there
How about, CLICK HERE 😉
January 18, 2010 at 5:41 pm #309056ukprometheus
what an idiott i am :rolls:
hotpoint FDW80 😛 does that help 8) also when the unit is not in use it slowly fills up, but takes a few days
January 18, 2010 at 5:50 pm #309057iadom
Apart from telling us that it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit that does make all the difference. 😀
Is the part you are fitting a C00098769 spray arm gasket?
I haven’t had to fit many of those, can’t see how that seal can catch once it is secured. 😕
Or do you mean the seal at the back of the cabinet that the spray arm pushes onto?What is the part number of the item you keep replacing?
Filling when not in use is either a faulty inlet solenoid valve or dodgy undersink plumbing.
Turn the water tap to the dishwasher off for a couple of days and see if that stops it filling when not in use.
January 18, 2010 at 5:55 pm #309058ukprometheus
its the nut at the back of the cabinet with a seal in it that the spray arm pushes onto when you push the basket in 😀
January 18, 2010 at 5:58 pm #309059iadom
Very strange, I have only changed an odd one of these, can’t say they have any previous as a constant failure point myself.
Perhaps one or two of the Comet/Indesit lads might have an answer, no mods listed.
It might be worth changing the bit that slots over the nut & seal at the same time.
January 18, 2010 at 6:01 pm #309060ukprometheus
well i have just ordered part number C00054862 from this site so maybe the ones i have been getting elsewhere are just cheap paton parts 😀
whats the inlet solenoid like to change
January 18, 2010 at 6:06 pm #309061iadom
According to my parts list the seal nut for an FDW80 is part number C00144315.
Solenoid valve is in the base, not that hard to change.
January 18, 2010 at 6:08 pm #309062ukprometheus
iadom wrote:According to my parts list the seal nut for an FDW80 is part number C00144315.
dont suppose you have a part number for the solenoid 😀
January 18, 2010 at 6:11 pm #309063iadom
Three different valves used, would need full serial number from rating plate to identify.
January 18, 2010 at 6:13 pm #309064ukprometheus
where would i find the rating plate 😯
and thanks so much for all your help fella, i checked this site for the the part number you quoted for the seal and it did not exist so i googled it and it looks the same but for ariston.
maybe the quality of the rubber is different depending on the supplier
January 18, 2010 at 6:18 pm #309065ukprometheus
if its the sticker on the side of the door there aint much left of it but i think its TYPE LS12-EV03 S/N FDW80 30714155 its a bit mangled the sticker
