hotpoint spray arm fixing nut
Home Forums Public Support Forums Help And Support Dishwasher Help Forum hotpoint spray arm fixing nut
Viewing 15 posts - 1 through 15 (of 20 total)
  • #51710
    ukprometheus
    i have a hotpoint dishwasher and the upper spray arm fixing nut seal keeps tearing where the basket is pulled in and out, what i am wondering is if there is a modified part i can use and this part only seems to last about 3 months
    #309052
    Re: hotpoint spray arm fixing nut
    Cough
    #309053
    ukprometheus
    iadom wrote:Cough
    sorry fella did i miss something there
    #309054
    spanishwhite
    Press your cursor on the word cough and it will give you a link as to what is needed.Without the model n0 etc the guys will have no chance in trying to help you.
    #309055
    How about, CLICK HERE 😉
    #309056
    ukprometheus
    what an idiott i am :rolls:
    hotpoint FDW80 😛 does that help 8) also when the unit is not in use it slowly fills up, but takes a few days
    #309057
    Apart from telling us that it is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit that does make all the difference. 😀
    Is the part you are fitting a C00098769 spray arm gasket?
    I haven’t had to fit many of those, can’t see how that seal can catch once it is secured. 😕
    Or do you mean the seal at the back of the cabinet that the spray arm pushes onto?
    What is the part number of the item you keep replacing?
    Filling when not in use is either a faulty inlet solenoid valve or dodgy undersink plumbing.
    Turn the water tap to the dishwasher off for a couple of days and see if that stops it filling when not in use.
    #309058
    ukprometheus
    its the nut at the back of the cabinet with a seal in it that the spray arm pushes onto when you push the basket in 😀
    #309059
    Very strange, I have only changed an odd one of these, can’t say they have any previous as a constant failure point myself.
    Perhaps one or two of the Comet/Indesit lads might have an answer, no mods listed.
    It might be worth changing the bit that slots over the nut & seal at the same time.
    #309060
    ukprometheus
    well i have just ordered part number C00054862 from this site so maybe the ones i have been getting elsewhere are just cheap paton parts 😀
    whats the inlet solenoid like to change
    #309061
    According to my parts list the seal nut for an FDW80 is part number C00144315.
    Solenoid valve is in the base, not that hard to change.
    #309062
    ukprometheus
    iadom wrote:According to my parts list the seal nut for an FDW80 is part number C00144315.
    dont suppose you have a part number for the solenoid 😀
    #309063
    Three different valves used, would need full serial number from rating plate to identify.
    #309064
    ukprometheus
    where would i find the rating plate 😯
    and thanks so much for all your help fella, i checked this site for the the part number you quoted for the seal and it did not exist so i googled it and it looks the same but for ariston.
    maybe the quality of the rubber is different depending on the supplier
    #309065
    ukprometheus
    if its the sticker on the side of the door there aint much left of it but i think its TYPE LS12-EV03 S/N FDW80 30714155 its a bit mangled the sticker
