Hotpoint tcfs83bgk(uk) not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint tcfs83bgk(uk) not heating
Viewing 15 posts - 1 through 15 (of 33 total)
  • #99840
    Pilch2k
    Hi all,
    The wife loaded soaking washing into the dryer when the filter clogged on the washing machine and turned it on!
    She can’t remember if the machine was turning but there was a burning smell and she turned it off. Now the drum turns but doesn’t heat. I tried resetting the thermostats on the heating element but had no joy. Bought a new heating element kit and thermos from espares website (ES1780421).
    Installed but still not heating. Everything appears to be getting power and has continuity, is there anything else I need to check?
    Thanks again.
    R.
    #478102
    have you put wet clothes in as a lot of machines wont heat till they are detected for energy saving
    Pilch2k
    Hi Dave,
    Yes I’ve tried, I don’t think it has sensor drying. But tried standard cotton and regular timed drying.
    The heater is getting power as I’ve tried a non contact voltage indicator. I didn’t know if there was another reset switch anywhere that I was missing in the dryer.
    Thanks.
    #478104
    the only dryer i can find with a model no close to your is full electronic and the model is showing as
    TCFS83BGK.9UK
    how old is yours?
    Pilch2k
    Hi Dave,
    It’s from 2016 tcfs83bgk(uk) 8kg sn 607146033 hotpoint aquarius.
    Thanks.
    #478106
    there must be another number on the label which is a commercial code
    have you got that ?
    Pilch2k
    Hi Dave,
    I have an ind code 95859770100, but nothing else.
    I can’t upload pictures due to size for some reason.
    Thanks.
    #478108
    Pilch2k
    Ours was offered as a replacement for the machines thst were part of the fire risk those years ago.
    #478109
    well for some reason the tech site knows about it but there is no tech for it at all
    its it board controlled or a mechanical timer ?
    Pilch2k
    Hi Dave,
    It must be board controlled as I don’t see a mechanical timer. It has a 2.3kw heater as stock, but compatable heaters are only 2.05kw with the model number. Maybe that’s the issue.
    https://parts.hotpoint.co.uk/categor…BGKUK?search=1
    Would the front thermistor stop the heating element from kicking in? Not that I can see one.
    Thanks.
    #478111
    1 did the connections of the new element look the same as the old unit
    2 lowering the element power wont cause any problems
    3 have you checked the water float in the pump housing ?
    4 if it has got a front NTC then yes as with every temp measing device it can alter things
    Pilch2k
    Hi Dave,
    Yeah the connections were the same.
    I did clean out the float and pump area, saw this advice on another thread and went back to double check it wasn’t engaged.
    I found the front ntc and it looks OK, reading ohms etc, but I’ve just ordered a replacement just in case.
    I’ve traced the power connecter from the dial (programme) selector to the ntc at the front and the power to the heater. Hopefully if the ntc is fried it won’t allow heater to engage and a replacement will fix it.
    Thanks.
    #478113
    have you tried it on a timed programme ?
    Pilch2k
    Yeah, still no heat. As in programme 12 is 40 mins of drying on a timed dry.
    #478115
    Pilch2k
    Well still no luck, contacted hotpoint who said I needed c00506093 which I bought which had the same heater in as the replacement which didn’t work.
    Tried changing the front thermistor too, no luck.
    Anything else to try before giving up?
    Thanks.
