Home › Forums › General Trade Forum › Hotpoint Tool Case 19
- This topic has 21 replies, 13 voices, and was last updated 9 years, 7 months ago by
Twoten.
August 22, 2016 at 1:44 pm #89117
Twoten
ParticipantI am getting to the point where I will have to replace my 14 year old tool case.
I quite like the GT Line cases https://www.toolventure.co.uk/Search.aspx?eaSearch=gt{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20case#
I have seen the Hotpoint tool case 19 listed on some suppliers sites but there are no images.
Is this a hard case like the GT Line?
Can someone who has one of these take a couple of photos, particularly the way the inside is configured so I can see what it’s like. Also, if you have one let me have your opinion of it?
Thanks,
Keith.August 22, 2016 at 2:15 pm #440371Lawrence
ParticipantRe: Hotpoint Tool Case 19
we use the Parat 433000171 ,find it on google ,prices vary
August 22, 2016 at 2:26 pm #440372Twoten
Lawrence wrote:we use the Parat 433000171 ,find it on google ,prices vary
Thanks, I will check it out.
August 22, 2016 at 4:03 pm #440373johnnyj
I have one it is made by Antler i think, you can get replaceable tool cards when they wear out, only time i got the case replaced was whe the feet broke off after years of abuse didnt want to damage somebodys flooring, similar to this http://www.ebay.co.uk/itm/Custom-Engine … 2104022773 cheers JJ
August 23, 2016 at 12:10 pm #440374wizard
Hi Keith, I spent a lot on a gt line case a couple of years back and always hated it. Partitions in lower section don’t stay where they’re put and unless you’ve got absolutely everything in a perfect position the lid won’t shut! Now there’s wearing in the hinges and stuff falls out. Won’t be having another, will probably go parat next time. Wiz
August 23, 2016 at 3:33 pm #440375Twoten
wizard wrote:Hi Keith, I spent a lot on a gt line case a couple of years back and always hated it. Partitions in lower section don’t stay where they’re put and unless you’ve got absolutely everything in a perfect position the lid won’t shut! Now there’s wearing in the hinges and stuff falls out. Won’t be having another, will probably go parat next time. Wiz
That’s worth knowing.
I can’t find anywhere locally that stocks any of these and I don’t like the idea of buying without seeing one first.August 23, 2016 at 7:30 pm #440376boselecta
My old Antler toolcase is coming to the end of its days.
Love to know where to get another one?.
(ex Comet engineers may recognise this)
August 23, 2016 at 11:18 pm #440377stratfordgirl
If you’re happy to consider an alternative style, Veto Pro Pac are the best tool cases I’ve found. Expensive but very hard wearing.
I use the Tech LC model, which has space for umpteen hand tools one side and large pockets for test meters, etc, on the other side. I find this carries all the tools I need for 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of jobs. A bigger version, the Tech XL, is also available.
Beesleys tools are the UK distributors:
August 24, 2016 at 8:55 am #440378Twoten
Thanks Stratfordgirl,
It’s an interesting idea. I used to use a tool bag but didn’t like everything ending up in the bottom and the zip was a pain. This looks like it would work though.
I like the hard tech cases because when open everything is laid out and easy to access.
I quite like the idea of one of the back pack styles. I have local supplier so will check it out.August 24, 2016 at 1:10 pm #440379EFS
I am on my second CK Magma toolcase and can highly recommend.
I like the shoulder strap which helps me to pick it up without bending my back.
And only £35.Steve
August 24, 2016 at 3:45 pm #440380Martin
I second Stratfordgirl’s choice. Quality toolbag that can contain all you could need and carry to the job without having to go backwards and forwards down the stair from the top flat just to get a socket set or soldering iron.
Quality and durability come at a price. These cheap plastic/material pockets soon fall apart once you’ve dragged a screwdriver in and out half a dozen times. And the straps holding them upright in the case break soon as looking at them. And when the shoulder strap breaks and your tool case falls on the ground crossing the high street I guarantee the passing no.3a bus will finish the job and make your day go even better! 👿
August 25, 2016 at 2:02 pm #440381Twoten
I had a look at some of the Veto Pro Pac’s earlier. They look durable option. Unfortunately they didn’t have the Tech-LC. They had the Tech-XL version but it’s a bit weighty @ 9.4lbs.
I hate making decisions.August 25, 2016 at 2:54 pm #440382Andy jones
I’m on my third magma tool bag now, straps keep breaking as do the Zips
August 25, 2016 at 3:12 pm #440383Twoten
Andy jones wrote:I’m on my third magma tool bag now, straps keep breaking as do the Zips
I think that rules that one out then.
August 25, 2016 at 3:49 pm #440384Andy jones
Twoten wrote:
Andy jones wrote:
I’m on my third magma tool bag now, straps keep breaking as do the ZipsI think that rules that one out then.
I may be guilty of over loading it though tbf
