Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD440 Power Module Situation
- This topic has 23 replies, 13 voices, and was last updated 17 years ago by
squadman.
March 23, 2009 at 7:28 pm #44472
squadman
ParticipantI have a Hotpoint WD440P which requires a new power module, partfinder lists C00254535 as being the replacment. I have tried Connect but it fails to say if this module is programmed or not. I have done a PNE and they sent the resolution back as requiring a hardware key ! That I and eady have but they cannot provide the smartcard partnumber and keep refering to the fact that the smartcard is for Hot & Cold Fill ?
The machine I have is cold fill only. I was under the impression that we could only now be supplied with blank PCBs with the Smartcard being ordered and configured via the hardware key. It seems that as far as connect are concerned no one has any logical answers.
March 23, 2009 at 7:37 pm #281063smartin
ParticipantRe: Hotpoint WD440 Power Module Situation
no less than 4 smartcards for this machine
C00262287= cold fill
C00262299=h/c fill
C00263494= ceset motor
C00267859= new heater boxmine field as it may even need a wiring change dependant on the module fitted
March 23, 2009 at 7:43 pm #281064squadman
So the next question is , how do we define what parts are required to effect this repair ?
I know that there are wiring loom replacements but surely Partfinder shold be the definitive resource so there are no problems sucj as this, they charge enough for it !!!!
March 23, 2009 at 8:04 pm #281065maltheviking
I have a WD420 with a faulty board same part no C00254535
smartcard C00262287, been waiting for a month for card to arrive as Connect only stock one type 😥
Been back to fit it today only to find I need a wiring change 👿 info on this courtesy of Hotpoint spares who convenently forgot to inform me when I first got the part no’s off them. Top and bottom of it is that Connect haven’t a clue and are not willing to sort the minefield out with Merloni.In the confusion, Connect have supplied me with two other board types, and an eeprom 😕 although boards are smartcard type 😕
Total cost of this repair will be a massive negative to me 😥 four visits to customer, plus a few hours on the net and phone 😥March 23, 2009 at 8:30 pm #281066squadman
This seems like an almighty cock up, Connect have been heavily pushing the hardware keys and low end adaptors, Indesit bleating on about simplifying the whole process using inovative smartcard technology and here we are with no information, no support, and evidently no stock, what chance have we got !!!!
March 23, 2009 at 8:41 pm #281067smartin
sent you a pm
March 23, 2009 at 9:37 pm #281068helo_75
Participantsimply, if the board has a j10 connection, it needs a wiring change, if not, then its a straight swap
its easy to have a look, just tip it back
March 23, 2009 at 9:45 pm #281069lerch
When fitting this module to a product produced before serial number 61101.0001 it will be necessary to convert the J10 connection
to J13 & J14 by fitting harness part codes C00142746 & C00142747. The module programme and function is not affected. 😀March 24, 2009 at 6:07 pm #281070Tony_EMW
Madness !! Just order from us and we send you the correct board, eprom fitted, eprom programmed, same-day ! £44.90+vat inc post ready to go and you can send it back if you mis-diagnose for £5+vat. Are you sure you guys really want to mess around with eproms, smartcards, smartcard readers, extra cost and delays ? Tony http://www.emwelec.co.uk
March 24, 2009 at 8:11 pm #281071deltra
EMW thats the way to do it.. 😉
March 24, 2009 at 8:18 pm #281072iadom
ModeratorRe: Hotpoint WD440 Power Module Situation
Last Friday afternoon, Indesit machine, suspected module and possible doorlock. Module posted off to EMW that afternoon.
Recieved repaired module back today with note advising of doorlock fault, fitted this afternoon, fault cleared. 8)
March 24, 2009 at 9:50 pm #281073rolf
I think I will give the hardware key and lowend adapters a miss.Sounds like a load of hassle to me.Plug and play thats what I like :rolls:
March 25, 2009 at 8:11 am #281074pup
deltra wrote:EMW thats the way to do it.. 😉
yep 😆
March 25, 2009 at 8:15 am #281075pup
iadom wrote:Last Friday afternoon, Indesit machine, suspected module and possible doorlock. Module posted off to EMW that afternoon.
i sent mine sat ,got it back tuesday,thanks to tony 😆March 25, 2009 at 9:10 am #281076admin
KeymasterRe: Hotpoint WD440 Power Module Situation
E M W……. EVERY TIME FOR ME……….. 😀 😀 😀 😀 😀 JOB DONE.
CANUFIXIT…
