Hotpoint WF430 Bearing Kit
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint WF430 Bearing Kit
Viewing 15 posts - 1 through 15 (of 20 total)
  • #26181
    Am I right in thinking you can’t buy a bearing kit for this model? Do you have to fit a WMA half drum and WMA spider? This is my first bearing job on one of these machines and I was feeling quite pleased about how much quicker you can get the tub out compared to a WMA but then I was disappointed to find my stock of WMA bearings won’t fit. 🙁
    #209057
    hotpnt
    Re: Hotpoint WF430 Bearing Kit
    Hi, the same rear half is used on wma and wf, the difference is in the electronics, its the same bearing kit also, what seems to not fit with the bearings?
    #209058
    Rear half has a different PN on Partfinder. 1603409 was/is the trade WMA rear half. Partfinder shows WF430 with 1605082 as rear half kit, unless that kit includes the heater and pegs etc. Still lists the same bearing kit as WMA though.
    EDIT. If you punch in 1603409 it lists it as fitting the WF430 so I guess the 1605082 is the full kit. 🙂
    helo_75
    am i correct in thinking there were actually 2 sizes of shaft on the wma?
    the earlier shaft was 35mm, im sure the later one was only 32mm
    im sure someone will correct me, but im sure ive come across this one
    #209060
    There is a smaller bearing assembly fitted to some models, never actually seen one yet but it normally lists both alternatives on PF if they are used.
    The bearings are 6205 & 6206, this is the seal (sorry it’s out of focus I tried twice but the autofocus must aim at somewhere other than the centre of image):
    #209062
    hotpnt
    yep the 1605082 is the rear half with heater,
    #209063
    hotpnt
    hi phidom, what was the problem with fitting the bearings?,
    #209064
    hotpnt wrote:hi phidom, what was the problem with fitting the bearings?,
    As I said, the old bearings are 6205 & 6206 with the small seal shown in the photo. My 1004473 bearing kit is 6206 & 6207 with a bigger seal. The customer was not willing to pay extra for a half drum + spider so it was another abortive attempt at earning a crust 🙁
    #209065
    Dave_Conway
    For future reference, the 30mm bearing kit is part number 1604600 🙂
    #209066
    Thanks Dave. I see it’s about twice the price of the WMA kit and yet the bearings are smaller. At least the broken front bearing comes out easier than the WMA type.
    #209067
    just got a gen bearing kit for above 1604600 after waiting 3 weeks and hotperloni have wronly packed it and included a 6207 bearing which is miles too big
    #209068
    Dave_Conway
    I’ve got both 6205 and 6206 loose here spare if you want one to make the kit up 🙂
    PM me your address and I’ll whack it in the post.
    #209069
    thanks for offer Dave but have already sorted from loose bearings i had around but now i need another set and dont know if the next set will be the same will ring Qualtex next week and see if they have any idea
    thanks again for offer
    Is there a rear drum half complete with the smaller bearings?
    Just been to a WF440 with a rather large hole in rear half, machine only 16 months old, it has the smaller bearings so a 1603409 will not fit. Do I have to change rear half & drum support for larger type. ❓
    Also noticed that the complete drum assembly with the smaller bearings is much lighter than the earlier one. The balance weights appear to be larger to compensate. Would fitting the earlier large drum support & bearings not compromise the weight/suspension?
