Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMT05 Bearings
- This topic has 15 replies, 4 voices, and was last updated 19 years ago by
spinbin.
April 2, 2007 at 10:54 pm #26341
spinbin
ParticipantI’m getting a taste for fixing washers after doing the bearings on a Servis. Yeah I know, I must be crazy, but I enjoy fixing stuff. Nothing like repairing something and seeing it working again.
I’ve just been given this machine with a “doesn’t drain” fault. I thought it’d be simple and sure enough, a foreign object jammed in the pump rotor.
There is however a slight “clicking” from the bearings when the drum is spun by hand. Looking on the forum it seems that these machines are notorious for bearing failure. Early signs on this one I’d say.
I’m tempted to get a kit and replace them. I know that the rear drum half was modified and is a preferable replacement but I’m not shelling out for that. If I can sort it for £20 or less then I’ll do it, otherwise it’s not worth it.
So, is this a goer, or is it going to cost more?
By the way, I think it is under 5 years old but I’m not bothered. This is purely for my own gratification.
CheersApril 2, 2007 at 11:33 pm #209758Penguin45
ParticipantRe: Hotpoint WMT05 Bearings
You will need 1604770 – drum support and bearing kit (The shaft will be damaged) and 1603293 – tub half seal. spares@ukwhitegoods.co.uk will be able to get them for you, but £20 is optimistic, to say the least. It’s a tank out job, BTW – ghastly.
Penguin45.April 3, 2007 at 9:20 am #209759spinbin
Ok thanks Penguin. Thought that might be the case. Looks like it’ll go to a friend to be run into the ground! He could always take advantage of the warranty.
By the way, motor sounds quite buzzy on this. Checked the brushes and they look fine. I think it’s the Bosch motor. Normal?April 3, 2007 at 8:50 pm #209760hotpnt
hi, just a pointer, but when you say the ‘drum clicks’ are you sure its the bearings & not a motor segment? have you tried to turn the drum with the belt off to see if it still ‘clicks’?
April 4, 2007 at 9:40 pm #209761spinbin
Yes I thought it might be a motor problem so did check it beltless. Definitely a drum noise. No play in them as yet and not noticeable when it’s running, but no doubt there is some damage there.
Thanks for the advice anyway.April 4, 2007 at 10:46 pm #209762iadom
ModeratorRe: Hotpoint WMT05 Bearings
Unless there is a foreign body in the outer drum. 😉
‘Clicking’ is not something normally associated with bearing failure, steady build up of noise on spin, accompanied by rusty stains or signs of water leaks down the back of the drum yes, but not clicks.
April 5, 2007 at 12:02 am #209763Penguin45
Coin in a paddle is a good one for that……… :innocent:
April 5, 2007 at 9:35 am #209764spinbin
Ok I might check this out further. Couple of questions: Is the drum behind the paddles “open” so that you can see into tub when they’re removed?
How do you remove the paddles? I can see they slide forwards and backwards and I assume they fit ito a keyway in the drum but I don’t want to force them for risk of damage. Thanks for the replies.April 5, 2007 at 10:02 am #209765iadom
Use a thin bladed teminal screwdriver, slot it into the third hole from front and press down. When you refit the paddle be sure to raise up the small metal tag that you have depressed to release it. You can see into the heater well and drain sump, a good place for bra wires to collect.
PS. have you tried to get the belt back on yet. 😉
April 5, 2007 at 10:24 am #209766spinbin
Right, I’ll give it a go later.
Yes got the belt back on with a lot of cursing and swearing!! Had the machine on it’s side and managed to reach top and bottom to feed it on.
CheersApril 5, 2007 at 2:11 pm #209767iadom
Belt refit is a 30 second job, if you know what you are doing. 😉
April 5, 2007 at 5:20 pm #209768hotpnt
yep, lost count of the number of customers ive seen with skinless knuckles, but they can get a bit upset when you get the belt back on in one go!
April 5, 2007 at 6:04 pm #209769spinbin
Alright showoffs, what’s the secret? :worthy:
April 5, 2007 at 6:08 pm #209770Penguin45
We could tell you, but then we’d have to kill you…….. 😆
:p45:
April 5, 2007 at 6:27 pm #209771iadom
spinbin wrote:Alright showoffs, what’s the secret? :worthy:
Well, seeing as you asked so nicely, :rolls: 😆 Lash the belt to the drum pulley with a large plastic bag tie, loop belt over motor pulley, turn drum from inside door to wind belt onto drum pulley, cut off bag tie, job done. 8)
