Indesit Smart Card Reader
Viewing 15 posts - 16 through 30 (of 52 total)
  • #254283
    helo_75 wrote:Well if youd actually bothered to read what i wrote instead of jumping the gun as asual
    youd realise i said that u still need your harwdware key, for fault diagnosis and codes
    anything else youd like to comment on?#
    I think that you missunderstand my writing… I didn’t point the finger on your knowledge… only on Indesit technology…
    baron wrote:Like lerch told previously “SmartCard Reader”it’s also worse because if something happen in the writing process you will lose entire card (data will be erase in time of writing)…
    Do not understand that I have tought that you & lerch have told stupid information…
    Please, before taking any action against anyones opinion make sure that he wanted to say that…
    In new words: till now I have worked already on few Arcadia models and are a bit worse then earlier from programming and reading point of view… otherwise are the same SH…
    helo_75 which hardware key did you used on ARCADIA? in order to read last error or taking into test?
    #254284
    helo_75
    the same on you use for all the wf/wt machines
    its the same pcb, effectively
    but your right… the stuffs rubbish, all the same
    #254285
    Turbo
    Re: Indesit Smart Card Reader
    Hoping the smart card type boards will be available from EMW as this new set up seems a load of hassle
    Turbo
    #254286
    helo_75
    nah, quite simple, plug in the reader, insert card, wait 5 minutes, take card out, done
    no danger of putting eprom in wrong, or even the wrong eprom
    #254287
    helo_75 wrote:the same on you use for all the wf/wt machines
    Thanks for info… 8)
    until now I didn’t used Key in those, because I was afraid to not damage it (first time when I’ve sought Arcadia I was checked which pins are for power supply and did not matched with EVOI/EVOII/LowEnd and I didn’t found nowhere info about which Key version could be used)…
    #254288
    CometBez
    Helo is right, the old test key can only be used on the EVO2 boards, it does not work on the new Arcadia board.
    Also, if your little green light on your smart reader does not stay permanent green then the data has not transferred, so the card will not have wiped.
    It does appear that the new(?) EVO2 welded eeprom boards already have data on them, all we are doing is re-prog’ing them.
    Luv Merloni or what!!
    #254289
    hotpnt
    hi, which old test key were you trying to use on arcadia?, i use the black one to programme them, ok so far
    #254290
    CometBez
    Hi hpoint,
    The old black key is not supposed to be able to prog Arcadia as the processor does not recognise it, how the heck are you doing it, or are you referring to the EVO2 boards?
    Cheers
    #254291
    hotpnt wrote:hi, which old test key were you trying to use on arcadia?, i use the black one to programme them, ok so far
    I have C00095669 (that transparent one) which works, like I told before, with all models.
    I didn’t try it on Arcadia… Could I try? or not?
    I ask this because I do not want to damage it, I cannot manage to get another one…
    #254292
    helo_75
    interestingly, for the indesit with the board at the top, u will need the original hardware key, because youll need the adapter and cable to plug the smart card reader into
    the plot thickens
    #254293
    hotpnt
    ive only fitted 2 lower rear mounted arcadia modules so far, but programmed both with the black key that i use on evo 1 & 2 using mem writer
    #254294
    helo_75 wrote:interestingly, for the indesit with the board at the top, u will need the original hardware key, because youll need the adapter and cable to plug the smart card reader into
    the plot thickens
    if you mean for LowEnd I use adapter for the key… and thru serial cable for programming or diagnose with PC…
    hotpnt wrote:ive only fitted 2 lower rear mounted arcadia modules so far, but programmed both with the black key that i use on evo 1 & 2 using mem writer
    Thanks, I will use the key on next Arcadia PCB…
    #254295
    pen0668
    any one copied smart card before using as i think smart card reader formats card after successful load to board i have a smart card reader/wrighter ???
    #254296
    macmini
    Does anyone have a pic of the smartcard reader and also the cards themselves?
    I’m interested to see how they’re doing it.
    #254297
    smartin
    im working on that at the moment il let ya know how it goes 😆
