Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › KENWOOD KDW45X15 slimline dishwasher, E3 please help me find thermistor/stat
- This topic has 45 replies, 2 voices, and was last updated 6 years, 5 months ago by
magaduccio.
October 27, 2019 at 12:41 pm #96627
magaduccio
ParticipantHello – Owner of the above seeks help.
I now realise this is a crappy machine, and have learned my lesson. However I’m still reluctant to throw it away.
History
Drop-off in wash performance, now won’t progress in a cycle. Diagnostic gives E3 (couple of times to make sure).
Accessed gubbins, visually fine, checked water heater (30 ohm, fine). Checked pressure microswitch (because I could see it) on the side of heater, fine.
Can’t tell how to check thermistor/thermostat – where are they please?October 27, 2019 at 12:48 pm #464162magaduccio
ParticipantPS I have photos but am struggling to upload them.
October 27, 2019 at 1:01 pm #464163electrofix
Moderatorpost the photo on another site and post a public link to it
October 27, 2019 at 1:19 pm #464164magaduccio
Participantsorry I’m slow of thinking.
https://ibb.co/L1LsPg6October 27, 2019 at 1:21 pm #464165magaduccio
ParticipantThe bit with the two white thin wires is closed (does not conduct) – it is a tiny black proby thing, is that the thermistor?
The bit with the red-brown-black connector has two covered prongy bits, is that the thermostat?October 27, 2019 at 1:31 pm #464166magaduccio
Participantfor what it’s worth, the side view.
https://ibb.co/z7MFskSOctober 27, 2019 at 1:32 pm #464167electrofix
Moderatordoes not conduct on which resistance scale. this is probably a thermistor which could have a resistance up to 100,000 ohms
October 27, 2019 at 1:35 pm #464168magaduccio
ParticipantI didn’t fancy this guy’s 6-part odyssey https://eatingorangesandmakingids.blogspot.com/2015/10/kenwood-dishwasher-fun-kdw12st3a-part.html
October 27, 2019 at 1:39 pm #464169magaduccio
ParticipantThankyou Dave, I now remember that conductance is relative – and how to use my multimeter. The resistance across the tiny black proddy thing is 14300 Ohms, at T= say 15 degrees.
October 27, 2019 at 1:41 pm #464170magaduccio
ParticipantThis looks almost perfect against the NTC resistance-temp table I have.
October 27, 2019 at 1:43 pm #464171magaduccio
Participantwhich is 17.5k @15, 12k @20 degrees. So I’m guessing this is fine, leave that bit alone now. So I’m thinking that the 2-stubby prong bit with the 3 wires is likely the stat.
October 27, 2019 at 1:48 pm #464172magaduccio
ParticipantI have discovered that the bit on the black clip with the 2 stubby prongs is the turbidity sensor (which figures with the 2 prongs). So my search for the stat goes on!
October 27, 2019 at 1:51 pm #464173magaduccio
ParticipantIt might be easier for me to test from the PCB, which is accessible nearby
https://ibb.co/DrFSZS2 can anyone direct me to the stat terminals?October 27, 2019 at 1:51 pm #464174electrofix
Moderatorprobably not as the ntc is the thermostat this is probably a turbidity probe
if the heater is ok and the ntc my next check would be the relay on the pcb
after first checking the wire from the ntc to the boardDave
October 27, 2019 at 1:54 pm #464175magaduccio
ParticipantGreat minds think alike. Thanks dave. It’s rather different from the one in the manual but I’ll see if I can figure it out.
