KENWOOD KDW45X15 slimline dishwasher, E3 please help me find thermistor/stat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum KENWOOD KDW45X15 slimline dishwasher, E3 please help me find thermistor/stat
Viewing 15 posts - 16 through 30 (of 46 total)
  • #464176
    from the pic of the board I found the heater relay will be the biggest one
    magaduccio
    It turns out that wire is super long and much harder to check the continuity of than I imagined. All the joints at the back of the pcb look okay, I’m going to pore over the diagrams see if I can determine which points on the PCB should correspond with the thermistor’s, and get to them that way. Can anyone advise?
    Failing that, perhaps I could take the PCB to a technician to check cheaply?
    #464178
    magaduccio
    If it helps, I think this is my board https://i.ebayimg.com/images/g/0mkAAOSwOntcwMrH/s-l1600.jpg
    #464179
    yes that looks correct
    the large relay is used for the heater
    also check the continuity of the wire from the heater to the board in case its broken at the bottom of the door. very common on some machines
    magaduccio
    Looking at the manual – other faults (with the washing pump or drain) can also be responsible for E3. My rotor arms aren’t spinning, even on the rinse programme (which I don’t think uses the heater) – just to exclude anything I can check myself before getting help, could that be fouled somehow?
    #464181
    magaduccio
    I will check that, but my PCB is down at the bottom (not in the door), in a neat housing with all the other stuff, there would be no need to put the wire anywhere near the door hinge.
    #464182
    ok I see don’t know the models geography
    yes could be poor water flow check the impellor for debris
    magaduccio
    Thanks, I will. To correct my earlier statement – programs do “complete” there is just no activity in the tub. No water out the rotors, that’s the main symptom – (and the E3 error code on diagnostic – but not on normal program). The clear tanky bit (air breaker?) is a little bit mucky, I woulda cleaned it but everything has those clips on that I don’t understand, like once-only jubilees. Guess I need to start tackling them? Is there a knack?
    #464184
    don’t worry about air break. concentrate why you have no flow to the bars so go for the wash motor
    to loosen the clips insert a screw driver in the loop and flex it to stretch it and loosen clip. to tighten it again use side cutters or pincers
    magaduccio
    Sadly I suspect there will be no re-tightening of these clips – no matter I’ll pick up some jubillees if needed.
    Wash pump / motor assembly removed, few fibres in the impeller but not enough to impede rotation (it span reasonably before I cleaned it). Could only see through tubes, but it looked in good order. Cleaned impeller/screw and re-attached to motor. Motor was warm – resistance (of coil I think) ~117 Ohms, manual says 78-100 measured from PCB. Capacitor was attached and I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure I measured the correct 2.
    Could there be a blockage anywhere else, e.g. between the pump connector and the sump or is there another stage to check for blockages before I reassemble? Or can a competent Tech bench-test the motor/capacitor for me?
    #464186
    magaduccio
    Just checking, but that was the washing pump I just cleaned? (the fat cream bit with the heating element also in it) Just the manual also mentions a drain pump.
    #464187
    magaduccio
    Visual inspection of the plumbing I can get to looks ok, nothing obvious just beneath the arms attachment (in tub)
    Kind of service manual – i.e. some slight differences in machine – but this has been helpful.
    https://www.4kenwood.co.uk/images/mediator/90/service{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20manual{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20-{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20kdw45b13{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20(9249h{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}209250h)a{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2B{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}202013.3.6.pdf
    Mentions possibility of “weak capacitor” – could this be responsible? Is it worth swapping out?
    Throwaway culture is looking less bad to me now. My shoulder hurts, I lost my Sunday afternoon and I am still washing up by hand!
    #464188
    caps do go but normally in my experience the motor wont start if they go. you are saying the motor is running but you have no flow so it sounds like a blockage or an impellor problem
    magaduccio
    I don’t know the motor is running for sure. I heard a noise during the programme, but that was all.
    However, there were a few fibres and the screw on the impeller top was fairly loose (the fibres were on the screw under the head, so there was probably a wee gap. Could it have risen beyond the oblong bit of the shaft (6-7mm I’d say) and ceased to engage with the motor? Then I would have motor noise (and warm) but no impeller movement).
    In other words, is it worth reassembling and testing again, or is there anything else I can test/do while it’s in bits?
    #464190
    if the motor shaft would turn without the impellor then that’s it
