LG DIRECT DRIVE MOTOR
Viewing 15 posts - 1 through 15 (of 18 total)
  • #50768
    machineman
    Motor spins smooth when empty, when put on wash and full of water the motor jumps and makes a noice as if its struggling. is this motor or module?
    Lucky Goldstar
    #305896
    helo_75
    its normally the stator
    #305897
    Re: LG DIRECT DRIVE MOTOR
    Could also be the Hall effect(?) sensor which is attached to the stator. It’s a quarter of the price of the motor so worth trying if you’re self employed.
    Mike.
    #305898
    machineman
    Not the module?
    aqualectric
    I’m with Helo on this – had exactly that fault before. Drum turns smoothly by hand, load the drum and the coil gives a loud “electromagnetic” type hum like a large transformer. The drum will judder and sometimes turn a bit. Hum gets louder before the PCB cuts it off. Then it’ll try again.
    If this description is correct then it’s the stator. The stall sensor IIRC, cuts the motor if the drum jams; whereas on a belt drive machine, it would throw the belt. 😉
    Hope that helps,
    Steve.
    #305900
    machineman
    Spot on changrd stator AOK
    Thanks guys
    timdowning
    Good God you got that part in quick from somewhere!
    #305902
    machineman
    Van stock have loads
    robbra
    Got the same problem here, WM 14225.
    Machine man how can you have “loads” at around £110 at Connect. I’m jealous. What did you charge the customer?
    Is it an easy fix?
    Rob
    #305904
    aqualectric
    £90.91 + VAT @ Connect for me. :tongue:
    Try Qualtex for the stator; couldn’t find it on their site though…….
    Easy job – rotor (pulley) bolt off, pull the rotor off against the magnetic force. Then unplug the loom at the stall sensor and undo the 6 bolts that hold the stator to the back of the tub.
    Reassembly is a reversal of removal: just watch out when you put the rotor back on – the strong magnets can trap you finger.
    Hope that helps,
    Steve.
    #305905
    robbra
    Once again to the rescue….Thanks Steve 😉
    #305906
    neilsukwg
    machineman wrote:Motor spins smooth when empty, when put on wash and full of water the motor jumps and makes a noice as if its struggling. is this motor or module?
    Does this fault normally throw up any fault codes?
    #305907
    helo_75
    yes
    is it oL?
    i cant remember off the top of my head
    #305908
    odom
    Sorry to drag this up but got a the same fault. Is there any point trying to replace just the hall sensor first, or is it best to go for the stator?
    #305909
    keithwilliams
    i thought these “motors” had a 10 year warranty? is that parts and labour or just parts?
