Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG DIRECT DRIVE MOTOR
- This topic has 17 replies, 10 voices, and was last updated 16 years, 4 months ago by
machineman.
December 8, 2009 at 3:18 pm #50768
machineman
ParticipantMotor spins smooth when empty, when put on wash and full of water the motor jumps and makes a noice as if its struggling. is this motor or module?
Lucky GoldstarDecember 8, 2009 at 3:54 pm #305896helo_75
Participantits normally the stator
December 8, 2009 at 8:05 pm #305897leavemetogetonwithit
ParticipantRe: LG DIRECT DRIVE MOTOR
Could also be the Hall effect(?) sensor which is attached to the stator. It’s a quarter of the price of the motor so worth trying if you’re self employed.
Mike.December 9, 2009 at 12:17 am #305898machineman
ParticipantNot the module?
DaveDecember 9, 2009 at 12:24 am #305899aqualectric
I’m with Helo on this – had exactly that fault before. Drum turns smoothly by hand, load the drum and the coil gives a loud “electromagnetic” type hum like a large transformer. The drum will judder and sometimes turn a bit. Hum gets louder before the PCB cuts it off. Then it’ll try again.
If this description is correct then it’s the stator. The stall sensor IIRC, cuts the motor if the drum jams; whereas on a belt drive machine, it would throw the belt. 😉
Hope that helps,
Steve.
December 10, 2009 at 4:27 pm #305900machineman
ParticipantSpot on changrd stator AOK
Thanks guys
DaveDecember 10, 2009 at 4:30 pm #305901timdowning
Good God you got that part in quick from somewhere!
December 10, 2009 at 4:57 pm #305902machineman
ParticipantVan stock have loads
DaveFebruary 9, 2010 at 8:23 am #305903robbra
Got the same problem here, WM 14225.
Machine man how can you have “loads” at around £110 at Connect. I’m jealous. What did you charge the customer?
Is it an easy fix?
RobFebruary 10, 2010 at 1:54 am #305904aqualectric
£90.91 + VAT @ Connect for me. :tongue:
Try Qualtex for the stator; couldn’t find it on their site though…….
Easy job – rotor (pulley) bolt off, pull the rotor off against the magnetic force. Then unplug the loom at the stall sensor and undo the 6 bolts that hold the stator to the back of the tub.
Reassembly is a reversal of removal: just watch out when you put the rotor back on – the strong magnets can trap you finger.Hope that helps,
Steve.
February 10, 2010 at 8:26 am #305905robbra
Once again to the rescue….Thanks Steve 😉
February 12, 2010 at 4:33 pm #305906neilsukwg
machineman wrote:Motor spins smooth when empty, when put on wash and full of water the motor jumps and makes a noice as if its struggling. is this motor or module?
Does this fault normally throw up any fault codes?
February 12, 2010 at 7:03 pm #305907helo_75
Participantyes
is it oL?
i cant remember off the top of my head
July 5, 2010 at 12:32 pm #305908odom
Sorry to drag this up but got a the same fault. Is there any point trying to replace just the hall sensor first, or is it best to go for the stator?
July 5, 2010 at 4:32 pm #305909keithwilliams
i thought these “motors” had a 10 year warranty? is that parts and labour or just parts?
