Liebherr GN2323 Freezer not cold enough
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr GN2323 Freezer not cold enough
Viewing 15 posts - 1 through 15 (of 19 total)
  • #80848
    Colin Powell
    My Liebherr Freezer is running at -9C. The compressor cuts in and out so thermostat is ok.
    I have tried turning off for couple of days in case frost in system was to blame but now turned on again still runs at -9C.
    My guess is that the temperature sensor is faulty and I am planing to test it in the way that has been suggested in the help and advice section by removing it and connecting a multimeter to watch any values change when brought near to something hot.
    Can you please tell me how to remove the covers on the lugs near the top of the inner freezer walls? Are there then screws under these covers that will allow me to lower the area above where I hope to find the sensor(s). Also which sensor is likely to be the faulty one please.
    Colin Powell
    #414551
    ELDAR59
    Re: Liebherr GN2323 Freezer not cold enough
    hello, -9 is about the temperature that you’d expect if the fan was running, or if there was no effect of the fan running.
    by that, I mean if the evaporator is blocked with ice and there is no air flow that the appliance relies on for its efficiency.
    can you supply a service number?
    #414552
    Colin Powell
    Thanks for your reply. The service number is 0981 602-01
    #414553
    Colin Powell
    Would 2 days switched off not be long enough to melt any ice?
    #414554
    ELDAR59
    With the door open, maybe.
    If you pull the clips off either side the evaporator will swing down. Then you can take off the top insulation piece to expose the evaporator, when you could see if there was frost on it.
    How long has the freezer been turned back on for?
    #414555
    Colin Powell
    I’ve now swung down the evaporator and there is no ice (it,s been turned off now for a further 2 days now) and I can spin the fan blade freely.
    I’ve also now located the two sensors but difficult to disconnect at the back. Does the tray pull right out some how?
    #414556
    ELDAR59
    No, not at all.
    -9 would tell me that the fan isn’t working.
    The sensors plug into the pcb on the top. I’d check that the fan works when the evaporator is frosted and the door is closed.
    If the fan isn’t working, then your problem could be evaporator sensor 9590148, fan or pcb.
    #414557
    Colin Powell
    Shall I bypass the evaporator sensor at the PCB to see if the temperature drops enough to start the fan?
    #414558
    ELDAR59
    No.
    The pcb needs the impulse from the sensor to power the fan.
    #414559
    Colin Powell
    With the evaporator swung down I have now lifted the sensor out, replaced the polystyrene and hung the sensor just inside the door so that it will monitor the air temp rather than the evaporator temp.
    With the evaporator now secured back where it should be and after 6 hours my freezer has now reached -18C (temperature indicator set at -18C no longer flashes and the alarm light also is out + I have a thermometer in the freezer confirming -18C). The fan definitely works because I put a pen mark on one of the blades earlier and upon reinspection it had changed position.
    Is it now safe to assume that the evaporator sensor is faulty?
    If so, I will purchase one from your site.
    Is it in the form of a repair kit where I cut the existing wire to remove the old and connect the new?
    #414560
    ELDAR59
    The sensor has to touch the evaporator for the freezer to work properly. There is an air sensor too and the freezer electronics take into account the difference between the two sensors in order to function properly.
    The evap sensor switches on the fan and controls the defrost so I can’t understand why the fan is running or your methodology to be honest.
    Are you sure it’s the evaporator sensor you’ve hung out or could it be the air sensor?
    In terms of probability, your problem is likely to be with the evap sensor anyway.
    The sensor is in kit form and does involve cutting and re joining.
    #414561
    Colin Powell
    Thanks for the feedback. It is the evaporator sensor that I have re-routed to the general freezer area. I did this because I suspected the sensor to be faulty and stopping the freezer from getting down to -18C. By putting it somewhere warmer I figured that this would allow the general freezer area to get down to the previous evaporator temp before cutting out which it has.
    Also I am now able to put food in the freezer which is at the correct temp but I realise that this is a temporary fix and hopefully have eliminated other possible faults.
    I now feel quite confident buying the new sensor.
    #414562
    Colin Powell
    The sensor unfortunately has not done the trick. Can you give me the ref no. for the pcb please for my Liebherr GN2323? I guess that is the only remaining part that can have failed.
    Thanks, Colin
    #414563
    ELDAR59
    Hello Colin, I’ll look at the tech info for you in the morning.
    What are you experiencing at the moment?
    There has been two months since your last post and so your freezer must have worked fir a while since?
    #414564
    ELDAR59
    hi colin, as per your enquiry the part number for the pcb on your appliance is 6144436.
