Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Neff S4453N0GB/13 no water going in
- This topic has 25 replies, 5 voices, and was last updated 16 years, 11 months ago by
mfield.
April 28, 2009 at 12:50 pm #45293
mfield
ParticipantCan some one help me. My dishwasher is taking in no water. I have looked at it and it appears to be the Bitron 902 valve that is acting up. I was wondering could someone confirm this so I can go and buy a new part.
Any help would be great.
Regs,
M.
April 29, 2009 at 2:16 pm #285187mfield
ParticipantRe: Neff S4453N0GB/13 no water going in
Anyone got an answer to this? Thanks 🙂
April 29, 2009 at 2:26 pm #285188LJDomestics
There will be no one who could confirm this on a forum i wouldnt of thought …
We do try to help in stearing the public in the right direction but to ask someone to confirm it i guess maybe this is why u have not had a quick answer.. if we all could confirm a fault 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} on a forum i think we would be inclined to make money from doing so without having to leave the house.
You may want to be a little more specific in what happened..when it happened..things like that so we could “guide” you a little better?
April 29, 2009 at 4:04 pm #285189Martin
mfield wrote:I have looked at it and it appears to be the Bitron 902 valve that is acting up.
New valve = Part number 263789
April 29, 2009 at 4:46 pm #285190mfield
LJDomestics wrote:There will be no one who could confirm this on a forum i wouldnt of thought …
Many thanks for your reply. LJ. Basically when I turn the machine on to start, there is no water going into the machine. I removed the valve and I checked pipe that the machine takes in water from and that is fine. So I can only guess that it is a problem with the valve itself? The valve is run by electricity as far as I can see as there are electric cables running up to through the piping to the valve. What do you think.
April 30, 2009 at 1:08 am #285191Penguin45
Resistance through solenoid coil is……..?
April 30, 2009 at 9:27 am #285192mfield
Penguin45 wrote:Resistance through solenoid coil is……..?
He he! I dunno, I presume I’d have to pull out my multimeter and check that one as not all solenoid coils are the same 😕
April 30, 2009 at 12:38 pm #285193Martin
mfield wrote:He he!
You can say that again. 😉 Checking those valves with a multimeter is a true test of determination over the forces of adversity. Access to the point where measurement can be taken in the first place will keep you pleasantly occupied for many a while. 🙁
Good luck pal!:tup:
April 30, 2009 at 2:14 pm #285194mfield
Martin wrote:
mfield wrote:
He he!You can say that again. 😉 Checking those valves with a multimeter is a true test of determination over the forces of adversity. Access to the point where measurement can be taken in the first place will keep you pleasantly occupied for many a while. 🙁
Good luck pal!:tup:
So should should I check the resistance before I go ordering any parts Martin or is this a job for the pros?
I am feeling more inadequate in the self diagnosis of the problem as this thread goes on. 🙁
April 30, 2009 at 4:31 pm #285195Martin
mfield wrote:So should should I check the resistance before I go ordering any parts Martin or is this a job for the pros?
You are right to assume that the valve is at fault, and they do fail so that diagnosis is not beyond the bounds of reason. However, there could be other issues causing the same symptoms including pressure switch, blocked hoses and indeed faulty programmer.
I would always advise contacting a local engineer such as myself who would call, assess the problem and deal with it accordingly subject to your approval. Simply sticking a new valve unit in may well solve your problem but it also may not? It’s a gamble at this stage and no mistake. 😉
April 30, 2009 at 4:49 pm #285196mfield
Martin wrote:
mfield wrote:
So should should I check the resistance before I go ordering any parts Martin or is this a job for the pros?You are right to assume that the valve is at fault, and they do fail so that diagnosis is not beyond the bounds of reason. However, there could be other issues causing the same symptoms including pressure switch, blocked hoses and indeed faulty programmer.
Many thanks for the your replies Martin, you could come round and repair it no probs but the thing is I am in Southern Ireland where we get bent over on anything like this and I am sick to the teeth of the rip off culture over here especially with the way things are now. That is the main reason I said I’d give it a go. I’m handy at fixing most thing so that is the reason I am here now.
I even rang Neff about the part you posted earlier and it was more expensive than it is in the UK – typical!
Anywho, enough of the rant 😀
I figured it may be more than just the valve alright. It is making a kind of gurgling noise when turned on and no water is getting into the unit. I might open her up and take a look but the folks want their washer working and they may just have to fork out.
May 14, 2009 at 4:15 pm #285197mfield
I had a chap I know take a look at this, he says it is the timer that is gone and that it might be better off getting a new dishwasher?! 😮
Anyone have any experience with this?
May 14, 2009 at 4:43 pm #285198Galway
how did he determine it was the programmer.did he check hoses and pressure chambers etc?
May 14, 2009 at 5:09 pm #285199mfield
Galway wrote:how did he determine it was the programmer.did he check hoses and pressure chambers etc?
I didn’t see exactly what he did as I was not present at the time he looked at it. He just told me that the timer needs to be changed and it would be a big job.
He usually services Philips products.
May 14, 2009 at 5:38 pm #285200Galway
could well be but may be worth another look if he is not used to these m/c he may be missing something .it is usually some other comonent that is failing.
when you knock m/c on does it pump out first.
check all filters /hoses to sump
what end of country are you in? -
