Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › no heat again
- This topic has 18 replies, 6 voices, and was last updated 16 years, 5 months ago by
fastcam.
November 1, 2009 at 4:26 pm #49782
fastcam
ParticipantI have a creda tumble dryer. I have replaced the element and all 3 thermostats. The new thermostats failed after 2 weeks. I replaced them again and this time they lasted 5 weeks. What could be causing them to fail? Would i be better buying a new dryer?
November 1, 2009 at 5:21 pm #302275Turbo
ParticipantRe: no heat again
Is it a vented or a condenser dryer?
Guessing its a condenser dryer and you have an air flow problem ie blocked door filter, blocked condenser box, also don`t overload dryer and never stop it during the cycle unless you turn the dial to the last ten minutes and allow to run cool first.
If it is vented check the hose is not kinked and the vent grill is clear.Graham
November 1, 2009 at 5:23 pm #302276fastcam
ParticipantThe missus has just told me it happens when she empties the water container??
November 1, 2009 at 5:26 pm #302277Turbo
Is she stopping it mid cycle to empty container? Not a good idea if this is the case.
November 1, 2009 at 5:41 pm #302278fastcam
ParticipantShe never stops it mid-cycle,and always empties fluff from filter. The machine is around 8 years old now maybe time for a new one.
November 1, 2009 at 6:48 pm #302279iadom
ModeratorRe: no heat again
A full model number would help. 😉
November 1, 2009 at 7:20 pm #302280fastcam
ParticipantThe model no is CREDA T601CW. Hope this helps.
Thanks to everyone who has replied.November 1, 2009 at 8:09 pm #302281DAR01
Check that the Condenser Unit is not blocked with fluff, you should find it situated at front bottom left of machine,it just slots in so you should be able to pull it out.
Also when you have the unit out check that there is no fluff build up at the rear of where this unit slots in.Mike
November 1, 2009 at 11:30 pm #302282iadom
As has already been stated airflow obstructions are the main cause of this fault other than stopping the machine mid cycle before it has gone through the cool down period.
The aforementioned condensor should be cleaned at least once a week if the machine is in constant use. Flushing it through with a hose pipe is the best way if you have that option available.
November 2, 2009 at 7:39 am #302283twinspark
could be the float switch stuck in up position 😀
November 2, 2009 at 9:49 am #302284iadom
Wouldn’t cause the stats to fail though. 😉
November 2, 2009 at 7:58 pm #302285twinspark
if your stats have failed again !
is it the one shot??
are the terminal to the stats all good and tight??
have you repalced the motor capaictor??
let me know 😀November 2, 2009 at 8:21 pm #302286clivejameson
Are you sure you had the correct stat kit for the model :con:
November 2, 2009 at 10:50 pm #302287fastcam
ParticipantI have replaced them with the correct green spot stats for this model,the connections are good and tight and i haven’t replaced the motor capacitor. I had to replace the heater element and all 3 stats. The 1 inside the door which i think was ok anyway and the green spot stats at the rear of the machine.I have made sure the air flow is ok and that the condenser unit is clear and clean.
November 2, 2009 at 10:53 pm #302288iadom
The capacitor can fail, especially under load, not expensive and worth a punt as it does lead to stat failures.
