no heat again
Viewing 15 posts - 1 through 15 (of 19 total)
  • #49782
    fastcam
    I have a creda tumble dryer. I have replaced the element and all 3 thermostats. The new thermostats failed after 2 weeks. I replaced them again and this time they lasted 5 weeks. What could be causing them to fail? Would i be better buying a new dryer?
    #302275
    Turbo
    Re: no heat again
    Is it a vented or a condenser dryer?
    Guessing its a condenser dryer and you have an air flow problem ie blocked door filter, blocked condenser box, also don`t overload dryer and never stop it during the cycle unless you turn the dial to the last ten minutes and allow to run cool first.
    If it is vented check the hose is not kinked and the vent grill is clear.
    Graham
    #302276
    fastcam
    The missus has just told me it happens when she empties the water container??
    #302277
    Turbo
    Re: no heat again
    Is she stopping it mid cycle to empty container? Not a good idea if this is the case.
    #302278
    fastcam
    She never stops it mid-cycle,and always empties fluff from filter. The machine is around 8 years old now maybe time for a new one.
    #302279
    Re: no heat again
    A full model number would help. 😉
    #302280
    fastcam
    The model no is CREDA T601CW. Hope this helps.
    Thanks to everyone who has replied.
    #302281
    DAR01
    Re: no heat again
    Check that the Condenser Unit is not blocked with fluff, you should find it situated at front bottom left of machine,it just slots in so you should be able to pull it out.
    Also when you have the unit out check that there is no fluff build up at the rear of where this unit slots in.
    Mike
    #302282
    Re: no heat again
    As has already been stated airflow obstructions are the main cause of this fault other than stopping the machine mid cycle before it has gone through the cool down period.
    The aforementioned condensor should be cleaned at least once a week if the machine is in constant use. Flushing it through with a hose pipe is the best way if you have that option available.
    #302283
    twinspark
    Re: no heat again
    could be the float switch stuck in up position 😀
    #302284
    Re: no heat again
    Wouldn’t cause the stats to fail though. 😉
    #302285
    twinspark
    Re: no heat again
    if your stats have failed again !
    is it the one shot??
    are the terminal to the stats all good and tight??
    have you repalced the motor capaictor??
    let me know 😀
    #302286
    clivejameson
    Re: no heat again
    Are you sure you had the correct stat kit for the model :con:
    #302287
    fastcam
    I have replaced them with the correct green spot stats for this model,the connections are good and tight and i haven’t replaced the motor capacitor. I had to replace the heater element and all 3 stats. The 1 inside the door which i think was ok anyway and the green spot stats at the rear of the machine.I have made sure the air flow is ok and that the condenser unit is clear and clean.
    #302288
    Re: no heat again
    The capacitor can fail, especially under load, not expensive and worth a punt as it does lead to stat failures.
