power cut fried bosch steam oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum power cut fried bosch steam oven
Viewing 15 posts - 1 through 15 (of 22 total)
  • #98846
    mrfixxer
    a powercut has killed this steam oven at 3am in the morning 😮 thanks uk power.
    its a hbc26d550/01
    after pulling it out and taking a look i can see there is minimal parts inside,well it is a big kettle, but i did notice there is a small hairline crack on one of the resistors and a burning smell from the power board so i would assume that is the culprit.
    https://i.ibb.co/9h6nVr1/20201227-182030.jpg[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”853″,”width”:”640″,”src”:”https://i.ibb.co/9h6nVr1/20201227-182030.jpg”}[/IMG2]
    #473998
    mrfixxer
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”347″,”width”:”640″,”src”:”https://i.ibb.co/X4n6w2T/bosch.jpg”}[/IMG2]
    are these cracks indicative of a duff resistor ?
    #473999
    mrfixxer
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”1944″,”width”:”3587″,”src”:”https://i.ibb.co/JdY8hBP/bosch.jpg”}[/IMG2]
    #474000
    would need to see more of the board
    resistor is an inrush supressor and acts as a fuse. look like it should measure 47 ohms
    this feeds a rectifier and the 2 caps i think which should be rated 400v. There will then be a chip to lower the voltage
    mrfixxer
    electrofix wrote:would need to see more of the board
    ok
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”853″,”width”:”640″,”src”:”https://i.ibb.co/S5y9QV2/20201227-182057.jpg”}[/IMG2]
    #474002
    mrfixxer
    what’s the best way to test for faulty component’s ?
    #474003
    you would need to check each component with a meter. test depends on what that component is
    start with the resistor and see if it reads
    mrfixxer
    electrofix wrote:you would need to check each component with a meter. test depends on what that component is
    cheers
    will that resistor show a true value through while attached to the board ?
    #474005
    should do to be honest if its a bit lower its no problem what we are trying to find out if its blown and then it will be thousands if not millions of ohms
    mrfixxer
    electrofix wrote:should do to be honest if its a bit lower its no problem what we are trying to find out if its blown and then it will be thousands if not millions of ohms
    where could a buy a replacement resistor from ? or even a new board
    #474007
    Resistor should not be hard. Would need the value off it and then rs components should have. It looks like a 3 watt fusible resistor and all we need is the value in ohms. Looks like it may be 47 ohms from the colors. Yellow purple
    new board if available can be go here. https://www.bosch-home.co.uk/customer-service/spare-parts-search
    ​​​​​​​Dave
    #474008
    mrfixxer
    electrofix wrote:Resistor should not be hard. Would need the value off it and then rs components should have. It looks like a 3 watt fusible resistor and all we need is the value in ohms. Looks like it may be 47 ohms from the colors. Yellow purple
    ​​​​​​​Dave
    cheers seems these are cement wire round fusing resistors. i have used the resistor calc
    im reading right to left white violet then gold and gold. 9.7ohm tolerance 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    #474009
    mrfixxer
    Can’t see website seems to be down. As long as it’s fusible and about 3 watt should be fine. Resistance should be ok for the job.
    if new one goes pop as soon as you turn on we will have to look deeper
    I would also check the bridge rectifier to see if that’s short circuited
    mrfixxer
    electrofix wrote:Can’t see website seems to be down. As long as it’s fusible and about 3 watt should be fine. Resistance should be ok for the job.
    sadly the new one blew too 🙁
