Removed Thread
Home Forums UK Whitegoods Moderator/Site Admin Forum Removed Thread
Viewing 15 posts - 1 through 15 (of 98 total)
  • #14141
    I think the thread Bosch fridge freezer problem in the refrigeration forum should be removed. Its recently been resurected and is encouraging any old leads to be shorted on the module. Didnt want to do it without a second opinion.
    Mark.
    #158239
    Re: remove thread?
    What’s the problem, Mark?
    Re: remove thread?
    I reckon someone with any fault on any Bosch Fridge is going to read that and start joining leads together. Just thought it went a bit too far for public advice.
    #158241
    Re: remove thread?
    Ah – if you keep reading back there’s about 10 different threads all leading to wires being joined up! Doubt we’d get them all…….. Time for a carefully worder article perhaps?
    Dave_Conway
    Re: remove thread?
    I think some of that information has been gleened from another site, how did “The kit will short out two wires” get to “Cheers, I shorted out pin 1 and pin 2” as BSH Man didn’t tell him.
    It’s more a case of the public advising each other to be honest.
    Any other thoughts anyone ?
    #158243
    Re: remove thread?
    In case he comes back to anyone else, I have deleted a post from Cornflakes (Graham) advising a punter to test for power at the fan motor of his Hygena oven……..
    Re: remove thread?
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=10856
    Last post – too much info? I used to HATE earthing m/wave capacitors…..
    Re: remove thread?
    well, NigelS certainly likes to give freely of his knowledge, I found this very illuminating. 🙂
    http://www.ukwhitegoods.co.uk/modules.p … highlight=
    #158246
    Dave_Conway
    Re: remove thread?
    Yeah, I would edit it slightly TBH 😉
    #158247
    Re: remove thread?
    Done.
    How can I “unsticky” a post? I tried to do that to the AEG config code post in trade tech but couldnt work out how.
    #158249
    Just edit it and you should see the options along the bottom, just checkboxes.
    Re: remove thread?
    thanks Ken, can see that now, i was trying to do it on the moderation page.
    #158251
    Re: remove thread?
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=11548
    A slight lack of decorum
    Running in this forum…….
    Thought GB should know better by now……
    Re: remove thread?
    I rather liked Gegsy’s tongue in cheek reply. To be honest I found parts of the OP’s first and indeed subsequent posts to be, condecending, dismissive and somewhat rude.
    Why is when someone says ” I don’t wish to offend you but” they then go and do just that. 😥
