Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Replacing Hotpoint bearings
- This topic has 21 replies, 7 voices, and was last updated 18 years, 6 months ago by
mikeyman76.
October 2, 2007 at 9:07 pm #31045
mikeyman76
ParticipantHi All
A friend has asked me to look at her noisy Hotpoint WM???? washing machine. It sounds like a mouse squeaking whilst on the wash cycle, when in spin it sounds like something inside is about to drop off.
my question is, is this a common fault ? If its worn bearings are they easy to change ? and could it be suspension ? This is a fairly newish machine 5 years + i think.
What do u guys think, any help would be welcomed
Mike
October 2, 2007 at 9:16 pm #229478Penguin45
ParticipantRe: Replacing Hotpoint bearings
If it were a WM–, the job would be a doddle. If it’s 5 years old, it’ll be a WMA– and it’s an evil swine of a job – the only proper way to do it is to replace the rear tub half and the drum support.
Get the actual number and we can confirm for you.
October 3, 2007 at 10:21 pm #229479mikeyman76
OK just found out that it is a WMT03. So is this a doddle or a swine ? If its a doddle ill have a look at it, if its a swine ill tell her to get a new one
October 3, 2007 at 10:34 pm #229480richardable
wm washing machine bearings can be a doddle if, and it’s abig if, you can get the old bearings out! the “if” is the inner bearing outer shell can “weld” itself to the tub sleeve and cannot be knocked out. try spinning the drum by hand if you feel or hear a “lumpy” sound it will be the bearings, if you don’t it may be a cracked drum spyder.
please post results.
richardOctober 3, 2007 at 10:39 pm #229481iadom
ModeratorRe: Replacing Hotpoint bearings
THE WMT machine is the basically the same as the WMA. As Penguin45 says, not really a simple DIY job.
I would check the age very carefully, in fact if you post up the serial number we can date the machine with reasonable accuracy, look inside the door or on the door hinge.
If it is under five years old then don’t touch it, send for the Indesit Company and take advantage of the five year parts g/tee. The drum spiders do not crack on these machines.
If it is over five years old then a local independent may be able to effect a repair at a reasonable cost compared to buying a new machine. Remember you will have to spend £350.00 upwards to get something that will last, if you intend to change it for a £200/£250 machine then get it repaired.
October 3, 2007 at 10:40 pm #229482Martin114
Trouble is a WMT is the same as a WMA :sadder:
October 3, 2007 at 10:41 pm #229483Martin114
:waving:
October 3, 2007 at 10:45 pm #229484richardable
checking the age of the machine is ok but i’ve had more thsn a few customers who know it’s less than 5years old but don’t have proof of purchase. when they ring the un-help desk they don’t get the service without puchase date!
richardOctober 3, 2007 at 10:45 pm #229485iadom
WMT & WMA mmm, TA now where have I heard that recently. 😉
October 3, 2007 at 10:49 pm #229486iadom
richardable wrote:checking the age of the machine is ok but i’ve had more thsn a few customers who know it’s less than 5years old but don’t have proof of purchase. when they ring the un-help desk they don’t get the service without puchase date!
richardSorry Richard but you are wrong, if the serial number proves that the machine is under five years old, the Indesit/Hotpoint Company will almost always honour the warranty as long as the machine has not been tampered with. They may try their usual trick of offering to do the whole job for £149.00 which includes 12 months cover ( and costs £75.00 per annum to renew) but anyone with half a brain would just tell them to stick it and insist on the full repair for the £90.00 labour charge.
October 4, 2007 at 8:07 am #229487richardable
jim, not wrong, just posting the feed back i’ve had from hotpoint customers. it just maybe an unhelpfull customer service operator.
richardOctober 4, 2007 at 7:23 pm #229488mikeyman76
ok i now have the serial number of the WMT03 it is: 02128238
so does it mean the machine was made in december 02 ?
October 4, 2007 at 7:36 pm #229489iadom
Sad to say, its Feb 2002.
October 4, 2007 at 7:44 pm #229490mikeyman76
it would be wouldnt it !
Im having a look tomorrow night, if there is nothing obvious and the drum grinds when i turn it by hand, i will advise her to look for a new machine.
Thanks guys ill let you know what i find
October 4, 2007 at 10:53 pm #229491iadom
You could always try a local independent engineer. In 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of cases I can do this repair for around £120.00 in total. Not cheap but if the alternative is to go out and spend less than £300.00 on a replacement, a repair of this machine would be a far better option. The later, modified bearing seal has been far more reliable than the original.
