reset one shot toc
Viewing 15 posts - 1 through 15 (of 18 total)
  • #37242
    delta01
    found out recently you can reset tocs for hotpoint condenser by holding firmly between finger and thum and bang it down on bi metalic side, works a treat, obviously handy in some circumstances,
    #254038
    squadman
    Re: reset one shot toc
    Great idea but not that profitable I would say.
    #254039
    If it’s tripped, it’s done its job. If it’s reset, it will be out of calibration and therefore not safe.
    delta01
    its a bi metalic disc how can it be out of calibration ? also the toc that trips is always the left hand one usually because the customer has either opened the door b4 the cool down period or not cleaned the filters etc, or the motor action has failed due to a faulty capacitor etc. the advantage being you dont have to replace the toc with a new set again in a call back situation or a rental situation
    #254041
    Because one is a cycling stat and is designed to do just that – flex back and forth to control the temperature. The other is not.
    When you tell the judge “I only reset the one-shot three times before it burnt the house down”, I hope you feel secure in a job well done.
    You can buy a pattern set for £3, or £5.50 for gen – why take a chance on a safety issue?
    DPDOM
    I’ve not come across pattern cut outs.
    Do Elecrue do them?
    #254043
    Masterpart offer a set to replace 1701583.
    lerch
    I have reset them in the past but only if I have none with me, but you should always change them they only trip for a reason.
    But saying that I reset the one on my creda dryer about 2 years ago and not since.
    Think of it this way nice easy repair and a very small lay out on parts = HAPPY CUSTOMER 😀
    #254045
    Madmac
    If there is one thing i will NOT take any chances with in appliances its monkeying around with thermal overload protection in any way..
    simply aint worth it. 🙁
    #254046
    helo_75
    hear hear!!!
    i would never reset a toc.. find the fault, repair it, and change the stats as a kit
    the customer will not thank you for burning their £300,000 home down
    #254047
    DPDOM
    Not as bad as Hotpoint putting 2 cycle stats in the kit instead of a cut out.
    Who’s fault is that when it burns the house down.
    delta01
    iv never heard of a late type hotpoint dryer setting on fire for one thing the cabinet is all metal and the drum is also not like the old plastic drum models as i said before the usual cause of toc tripping is customer turning off without allowing cool down or overloading / not cleaning filters
    #254049
    helo_75
    but the fluff insdide isnt metal
    dont you do a lot of ctd/vtd dryers?
    #254050
    bobokines
    I can’t believe the number of times this subject comes up.
    Resetting a non-resettable TOC is total madness. Nobody here would short out a fuse in a plug! What’s the difference?
    It’s engineers that do these practices that give this industry a bad name.
    Rant over!
    Bob
    #254051
    Micky 32
    I called to a house once to look at a washing machine. They said they had a hotpoint condensor dryer that they didn’t want as they got new stuff in the house so i took it. They said it was working but the clothes were getting a little hot. When i opened it the one shot stat had wire bridged over the terminals! Some electrician guy did a repair on it 2 years previously.
