Home › Forums › Public Support Forums › International Forums › European Appliance Forum › Samsung American Fridge Freezer RS20CCMS losing temp
- This topic has 24 replies, 5 voices, and was last updated 18 years, 2 months ago by
Ralphy.
January 19, 2008 at 9:53 am #33831
Ralphy
ParticipantI have a Samsung American Fridge Freezer, model RS20CCMS the fridge side temperature gauge is flashing at 2, however the fridge doesn’t appear to be this temperature, does anyone know what the problem is? and how to fix it. Freezer appears to be working normally.
January 19, 2008 at 10:24 am #240226admin
KeymasterRe: Samsung American Fridge Freezer RS20CCMS losing temp
hhi
the problem could be either the defrost sensor or heater or evap cover,If you press the light switch in on the fridge side when the door is open do you hear or feel any air coming out of the vents at the rear of the fridge ?
do you have any noise coming from the fan ?
Bryan
January 19, 2008 at 1:38 pm #240227Ralphy
ParticipantRe: Samsung American Fridge Freezer RS20CCMS losing temp
r600a wrote:hhi
Bryan
Hi Bryan
I have tried this, and I cannot feel any air coming out of the vents at the rear of the fridge, the unit only appears to be serviced by 1 fan which is located in the rear of the freezer, do you know anything I can try to get these working.Thanks
January 19, 2008 at 6:42 pm #240228admin
Then the fault will be the defrost sensor in the freezer section,its got a yessow lead with a white buttit end.
Bryan
January 19, 2008 at 7:22 pm #240229Ralphy
r600a wrote:Hi
Bryan
Hi Bryan
Where could I purchase one of these from & are they easy to install.Thanks
January 19, 2008 at 8:03 pm #240230admin
Either from myself or the online shop.
Bryan
January 19, 2008 at 8:05 pm #240231Penguin45
Have a look here:
http://shop.ukwhitegoods.co.uk/index.ph … 7_492_1108Degree of difficulty; I’m afraid I have no idea!
January 20, 2008 at 11:11 am #240232Ralphy
r600a wrote:Hi
Bryan
Hi Bryan
The fridge has come back up to temp if you could provide me with your number to ring you to discuss the matter furthur this would be appreciated.
Best Regards.
Ralph.January 21, 2008 at 8:37 am #240233Ralphy
ParticipantHi Bryan can you arrange for me to purchase a defrost sensor if that is the probable diagnosis.
Regards.
Ralph.
January 22, 2008 at 5:19 pm #240234Ralphy
ParticipantOrdered part DA3200024B does the fridge freezer need to be switched off for installation and if so for how long.
RegardsRalph.
January 23, 2008 at 4:17 am #240235admin
yes the appliance needs to be switched off to carry out any repair !!.I recomend 24hrs with both doors open to make sure it has defrosted completely.
They are easy to replace as they can only be fitted into the correct plug unless you force it.
Bryan
January 23, 2008 at 7:43 pm #240236Ralphy
r600a wrote:Hi
Bryan
Hi Again
I have received the part today, a Fridge Thermistor, is this the correct part, the part number is SAMDA3200024B, ordered from the website, as the cable is blue and you did mention it would be yellow.Thanks
March 26, 2008 at 8:37 pm #240237Ralphy
Help required fitted new defrost sensor to appliance lasted for about 4 wks same old problems occurring fridge temp flashing and not cooling refrigerator side any help would be appreciated.
Thanks.
Ralph
March 26, 2008 at 9:05 pm #240238admin
The problem will lie within the defrost system.send me a pm.
Bryan
March 27, 2008 at 7:53 am #240239Ralphy
ParticipantHi not sure what you want me to send as this model does not display any error codes.
Thanks.
Ralph.
