Samsung American Fridge Freezer RS20CCMS losing temp
Home Forums Public Support Forums International Forums European Appliance Forum Samsung American Fridge Freezer RS20CCMS losing temp
Viewing 10 posts - 16 through 25 (of 25 total)
  • #240240
    lee8
    Re: Samsung American Fridge Freezer RS20CCMS losing temp
    The problems with the samsung lie within several badly designed components.
    The cause depends on one the Ice pattern, if the Ice is around the fan, then the Modified cover is required to allow heat from the defrost heater to conduct into the cover and prevent blockages in the air channels.
    If the Ice pattern is solid around the evaporator then either the Thermal Fuse is O/C or the Heater is O/C.
    If the Ice pattern is solid around the drain channel then the drain heater O/C or the drain hole has become blocked.
    Its recommended that all Samsung models that haven`t got the replacement NTC and ducts get them replaced at the same time.
    Not always a simple Sensor fault.
    #240241
    Ralphy
    hi can anyone assist as am a novice at this and is it expensive to repair?
    #240242
    Hi Ralphy,
    In all honesty this isn’t a repair for a novice, especially if you are faint of heart.
    If I were you, after last night’s Watchdog, I’d call Samsung on 0800 988 0123 and see if they can offer any help. 😉
    Ralphy
    Thanks kwatt my dilemma is it worth having it repaired ?
    #240244
    Hi Ralphy,
    Read and watch the video in this news article 😉
    HTH
    Ralphy
    interesting, however this is the model which proceeded mine which is the rms20 might be worth giving them a ring.what do you think?
    #240246
    No harm in trying, they can only say no. 😉
    Ralphy
    Thanks for your help, you have cheered me up a little bit.
    #240248
    Ralphy
    Hi can anyone tell me if this is any good,Amana SAC224GB and whats a reasonable price to pay?
    #240249
    Ralphy
    model saa224gb sorry
