Samsung American Fridge Freezer RS20CCMS losing temp
Home Forums Public Support Forums International Forums European Appliance Forum Samsung American Fridge Freezer RS20CCMS losing temp
Viewing 15 posts - 1 through 15 (of 25 total)
  • #33831
    Ralphy
    I have a Samsung American Fridge Freezer, model RS20CCMS the fridge side temperature gauge is flashing at 2, however the fridge doesn’t appear to be this temperature, does anyone know what the problem is? and how to fix it. Freezer appears to be working normally.
    #240226
    Re: Samsung American Fridge Freezer RS20CCMS losing temp
    hhi
    the problem could be either the defrost sensor or heater or evap cover,If you press the light switch in on the fridge side when the door is open do you hear or feel any air coming out of the vents at the rear of the fridge ?
    do you have any noise coming from the fan ?
    Bryan
    #240227
    Ralphy
    r600a wrote:hhi
    Bryan
    Hi Bryan
    I have tried this, and I cannot feel any air coming out of the vents at the rear of the fridge, the unit only appears to be serviced by 1 fan which is located in the rear of the freezer, do you know anything I can try to get these working.
    #240228
    Then the fault will be the defrost sensor in the freezer section,its got a yessow lead with a white buttit end.
    Bryan
    #240229
    Ralphy
    r600a wrote:Hi
    Bryan
    Hi Bryan
    Where could I purchase one of these from & are they easy to install.
    #240230
    Either from myself or the online shop.
    Bryan
    #240231
    Have a look here:
    http://shop.ukwhitegoods.co.uk/index.ph … 7_492_1108
    Degree of difficulty; I’m afraid I have no idea!
    Ralphy
    r600a wrote:Hi
    Bryan
    Hi Bryan
    The fridge has come back up to temp if you could provide me with your number to ring you to discuss the matter furthur this would be appreciated.
    Best Regards.
    Ralph.
    #240233
    Ralphy
    Hi Bryan can you arrange for me to purchase a defrost sensor if that is the probable diagnosis.
    Regards.
    Ralph.
    #240234
    Ralphy
    Ordered part DA3200024B does the fridge freezer need to be switched off for installation and if so for how long.
    Regards
    Ralph.
    #240235
    yes the appliance needs to be switched off to carry out any repair !!.I recomend 24hrs with both doors open to make sure it has defrosted completely.
    They are easy to replace as they can only be fitted into the correct plug unless you force it.
    Bryan
    #240236
    Ralphy
    r600a wrote:Hi
    Bryan
    Hi Again
    I have received the part today, a Fridge Thermistor, is this the correct part, the part number is SAMDA3200024B, ordered from the website, as the cable is blue and you did mention it would be yellow.
    #240237
    Ralphy
    Help required fitted new defrost sensor to appliance lasted for about 4 wks same old problems occurring fridge temp flashing and not cooling refrigerator side any help would be appreciated.
    Thanks.
    Ralph
    #240238
    The problem will lie within the defrost system.send me a pm.
    Bryan
    #240239
    Ralphy
    Hi not sure what you want me to send as this model does not display any error codes.
    Thanks.
    Ralph.
