Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Samsung Washing Machine 3e error : model WF1804WPN
- This topic has 15 replies, 2 voices, and was last updated 8 years, 3 months ago by
rebelINS.
January 15, 2018 at 1:57 pm #93076
rebelINS
ParticipantHi,
Currently following this video
https://www.youtube.com/watch?v=_H6EDqujxDU
to try and repair the 3e error on my washing machine. However, the electric connection to the Welling motor won’t come off – in all the videos I’ve seen it clicks off with ease, but it won’t come off.
Pictures of the motor/connection:
https://ibb.co/gpU9wm
https://ibb.co/gG2CGm
https://ibb.co/k4psGm.Pictures of the carbon brushes:
https://ibb.co/eYzyp6
https://ibb.co/eFE9wm
https://ibb.co/nOy2Gm
Anyone have any idea how to disconnect the electrics from the motor? And from looking at the brush pictures, is it probably the brush wear that is causing the 3e error?Thanks
January 15, 2018 at 3:04 pm #453129electrofix
ModeratorRe: Samsung Washing Machine 3e error : model WF1804WPN
if you think its the brushes just remove one to see. there is no need to take the main wire off the motor unless you want to
also from the utube video and your motor pictures the brushes look like these
https://shop.ukwhitegoods.co.uk/047317- … ushes-8215
double check with the shop first that they will fit but they look right
January 15, 2018 at 4:39 pm #453130rebelINS
ParticipantRe: Samsung Washing Machine 3e error : model WF1804WPN
Ok so I managed to take the main wire off anyway, as well as the brushes:
https://ibb.co/gugmRm
https://ibb.co/k1DcXR
https://ibb.co/mjM36m
https://ibb.co/caJammOn the last pic you can see the difference between the two: the longer one has a shiny end, whereas the shorter one is black.
Judging from the wear do you think the problem will disappear by replacing the brushes? I don’t know what else to check for with the motor other than cleaning the comutator as in the video.
In terms of replacement, could you point me in the right direction? Here are the codes on the sides of the brushes:
https://ibb.co/m68amm
https://ibb.co/fbheCRThanks
January 15, 2018 at 7:11 pm #453131electrofix
yes they are worn out and yes that is most likely your problem
January 16, 2018 at 10:37 am #453132rebelINS
o I did some research and the machine itself, which I bought from Currys 5 years ago is a retail special model. After ringing Currys, they can’t identify the particular part but this is the motor: https://www.buyspares.co.uk/motor-01-14 … =3378481BS
Which is a problem as I only want the brushes.I’m seeing a lot of similar looking brushes online, how much do they actually differ?
https://shop.ukwhitegoods.co.uk/047317- … ushes-8215 (from the poster earlier)
https://www.4washerhelp.co.uk/washing-m … 481:496051
Would either work, as they are both Samsung brushes apparently.
I found an Amazon link where a guy reviewed it saying they fit his WF1804 Samsung machine – which is the first 6 digits of my model.
https://www.amazon.co.uk/dp/B00XUC797W/ … _dp_review
Are there any risks of using the wrong one? Will it just not fit if it is wrong, or is there any fire risk or something?
What do you think my best bet is?
January 16, 2018 at 11:05 am #453133electrofix
all those brushes are mostly the same. there are 2 kinds of spares in this trade. you have a choice between the genuine spare and a pattern one made to fit. in some cases the genuine spare is worth the extra because of higher build quality
the genuine equivalent to the link I posted above is
https://shop.ukwhitegoods.co.uk/047317- … on-brushes
what you have to understand is appliance manufacturers don’t make the motor they just buy it in. This means the same motor can be used on different makes of appliances
if the brush is the wrong one it wont fit properly on the motor or may cause excessive sparking when in use while it beds in
January 16, 2018 at 11:12 am #453134rebelINS
Also, a lot of the brushes say they are for the PA66 which I assume refers to the motor?
How can I tell if mine is the PA66?
Motor: https://www.buyspares.co.uk/motor-01-14 … =3378481BS
Sticker on the motor: https://ibb.co/dqoqMm
January 16, 2018 at 11:20 am #453135electrofix
from an Amazon link
https://www.amazon.co.uk/SPARES2GO-C001 … 66+brushes
they give PA66 and also the gen hotpoint number C00196539 which is the same as the link I posted aboveI am 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} these brushes will work. can never be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} in anything in life
January 16, 2018 at 12:29 pm #453136rebelINS
electrofix wrote:from an Amazon link
The brushes I took off don’t have the circled thing. Reckon that makes a difference?
January 16, 2018 at 12:48 pm #453137electrofix
that’s to hold the wire going to the brush to stop it moving and snapping and no if yours has not got that makes no odds
what matters is
A) position of screws and small lugs that locate brush
B) the angle of the end of the carbon brushDave
January 16, 2018 at 1:13 pm #453138rebelINS
electrofix wrote:that’s to hold the wire going to the brush to stop it moving and snapping and no if yours has not got that makes no odds
what matters is
https://www.amazon.co.uk/Washing-Machin … op?ie=UTF8
Can you tell if the slant/brush angle in these are the same as in my pic:
I’m having a difficult time telling
January 16, 2018 at 1:18 pm #453139electrofix
the angle of the top of the brush goes up from left to right while viewing brush holder from underneath as in your photo. and yes all those do the same as does
as does the link to the gen brushes I posted higher up
January 20, 2018 at 10:57 am #453140rebelINS
electrofix wrote:the angle of the top of the brush goes up from left to right while viewing brush holder from underneath as in your photo. and yes all those do the same as does
Hi Dave,
Thanks for your help so far. After the parts came, I replaced the brushes and the machine was working again. However, one thing I did notice was that at high spins the machine sounded a little louder (Maybe I’m just noticing more now). Last night, I’m pretty sure the belt came off as the drum won’t spin but you can hear the motor – I’m going to check later today.
I had difficulty putting the belt back on after changing the brushes. I put the motor in place but didn’t screw the bolts, then attached the belt to the motor, screwed the bolts in, then put the belt on the rest of the pulley as in this video https://www.youtube.com/watch?v=_H6EDqujxDU . (It wouldn’t fit if I screwed the motor bolts in first – the belt would just lop off the black thing with grooves on the motor).
Also what I found was the edge of the belt would almost slip towards my side (as opposed to the washer side) on the pulley. Like there is a slight overhang of the belt on the pulley rather than being in the middle. The belt has grooves in it from the previous 5 years of spinning. I’d try to push the belt in the middle, but when I spun the pulley with my hand the belt would move slightly to have a small overhang and be stable there. I put everything back together and the washing machine has worked well for the past 2 days (other than my observation that at high spins it seemed a little louder) but then the belt came off last night.
Do you have any ideas on how to solve this? I’m going to put on the belt again but if it comes off again, clearly there’s a deeper issue?
January 20, 2018 at 11:07 am #453141electrofix
this has all the makings of a drum bearing issue
since we seem to love utube watch this
https://www.youtube.com/watch?v=wUL5Wb1T71cDave
January 20, 2018 at 5:36 pm #453142rebelINS
electrofix wrote:this has all the makings of a drum bearing issue
I don’t think the machine makes a noise like the machine with worn bearings in the vid makes when it span, nor is there movement of the drum with regards to the seal.
I’m having an issue getting the belt back on (as I did previously after replacing the brushes.
I try to line up the belt as far back on the black thing (towards the machine rather than towards me) then put the half of the belt on the pulley as I rotate it. Then I screw in the bolts holding the motor (the original video posted said this was because the motor moves it’s position so you half attach the belt then screw) then rotate the pulley further until the belt goes on. This method worked eventually the first time, but then as well as now, the belt keeps moving towards me, i.e. off the black spindle, when I try to put on the remaining bit of the belt.
Whereabouts should the belt be on the spindle? When I refitted the belt previously, it was close to me, and as said earlier, there was a slight overhang of the belt on the pulley towards my side, which probably caused the belt to come off.
Why does it keep moving off the black spindle when I try to attatch it/rotate the pulley?
