Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens Siwamat 6102 Washing machine Error code 4
- This topic has 15 replies, 7 voices, and was last updated 19 years, 11 months ago by
Sati.
April 29, 2006 at 5:28 pm #17472
Sati
ParticipantIts lasted this long but finally its come up with error code 4 and doesn’t spin. Not pulling the damn thing out till I find out what the error means first this time. 🙂
Its a Siemens Siwamat 6102 washing Machine.The Enr number is WE61020GB/01
The fd number is FD 76065 00042April 30, 2006 at 8:01 am #174513linrew
ParticipantRe: Siemens Siwamat 6102 Washing machine Error code 4
hi
error code 4 is motor not turning correctly
POWER OFF then remove motor and check brushes. (probably worn out)
linrew
April 30, 2006 at 9:57 pm #174514Sati
Could that mean that the belt has broken? Or could it be that the motor is knackered completely? Its not spinning at all at any stage of a cycle.
April 30, 2006 at 10:10 pm #174515whitevanman
A phyical look is worth it ❗
Appoligies in the first instance, ‘ref no pulling it out’ I suppose one of the dreaded fears on anyone in the white goods trade is some kitchen fitters looks a nice instalation to some of these guys, but no thought likewise if the appliance fails, you got someone out to check this fault, they may charge for time (time=money) or you could pull the appliance out yourself and take a peek.
Power off first :zap:
Hope this helps
Wvm
April 30, 2006 at 10:42 pm #174516Penguin45
If I might elaborate slightly……
Your appliance uses a carbon brush drive motor and is 10 years old – the brushes are a consummable item. 10 years is a damn good run! It’s not actually a fault, it’s a maintenance job. You might like to check this:
http://www.ukwhitegoods.co.uk/modules.p … rush+motor
If you’re not confident, please get pro help – check the link in my signature. If investigating further please ensure the power is off.
The belt almost never breaks on these appliances, BTW 😀 .
Penguin45.April 30, 2006 at 10:43 pm #174517gegsy
For starters its GB/11. The belt being broken would make no difference as linerw said check brushes.
April 30, 2006 at 10:44 pm #174518gegsy
Hi Chris :wave:
April 30, 2006 at 10:58 pm #174519whitevanman
Hi all :wave:
April 30, 2006 at 11:31 pm #174520Penguin45
:wave: Eh-o
May 1, 2006 at 12:23 am #174521Trilobite
Penguin45 wrote::wave: Eh-o
Oh my God! The Tellytubbies!!! 😯
May 1, 2006 at 12:32 am #174522Penguin45
This is Yorkshire – TetleyTubbies……. 😀
May 1, 2006 at 8:29 am #174523Sati
I’ve taken the motor out and not sure how to get the brushes out. I take it I don’t have to take the whole of the end of the motor off ?
There’s a spade connector on each brush which I can remove. But how do I get the brush out? Are there any push in tabs etc? The motor is a 3047807AA4 18A6765-0HB 230/240 50HZ.May 1, 2006 at 10:19 am #174524Penguin45
Have a close look at the tab the connectors push onto – there will be two little cutouts. With a pair of pointy pliers, push the tab across until the cut-outs line up with the brass tube, lift the tab, then ease it back to release the other end.
You will probably find that the brushes are slightly unequal in length and that one will have a shiny tip, whilst the other is dull black. That being the case, they are finished. They actually start out over an inch long and getting the new ones in against the spring pressure is much more fun 🙁 .
Penguin45.May 1, 2006 at 10:24 am #174525Sati
Exactly as you said. One of the brushes had obviously burnt out and both are worn down to near the brass. Just ordered some new ones so should be up and running in a few days. Many thanks.
May 1, 2006 at 11:27 am #174526gegsy
Two different makes of motor on this appliance Sati.
You will need to locate make of motor and choose from below.Siemens – 154740
FHP – 167517Both sold in pairs and available from link below.
Regards
