Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SIMPLE PCB REPAIR TIPS
- This topic has 82 replies, 41 voices, and was last updated 16 years, 2 months ago by
iadom.
February 5, 2013 at 11:52 pm #309708
Hollytree_Technical
ParticipantRe: SIMPLE PCB REPAIR TIPS
Electrolux EWM1000 Washing Machine Control Board
Symptoms: Machine goes dead after a few minutes regardless of program or if it is running.Cure: Replace the microchip at position U5
Jem
March 4, 2013 at 7:26 pm #309709Alanj
MIELE EL200 D PCB
There are post in the forums about this, but thought it would be helpful here.
Fault after switching on a program, rinse light flashes indicating no spin/motor fault.
Find the small round reddish brown fuse, if o/c chances are orange relay contacts are
welded together. Change both and should be good to go. Cost of repair to board approx £8-10.
Parts from http://www.farnell.co.uk Relay Part No.1629053. Fuse Part No. 1596442April 9, 2013 at 4:57 pm #309710iadom
ModeratorRe: SIMPLE PCB REPAIR TIPS
One from a member of the public. 😀
Hotpoint TDC dryness module, no heat fault.
1x RT314024 and 2x RT114024 required.
May 15, 2013 at 12:37 pm #309711electrofix
zanussi FL1045w
fault washes ok but fails to gain full spin speed
cure 1uF cap on programmer to supply power to electronics
October 19, 2013 at 4:12 pm #309712electrofix
Gram Fridge K400RU and similar freezer
danfos board 077F2310BJ and 077F2311RU
was asked to take a look at this unit and a freezer of the same make
both these units use a small Danfoss control board mounted at the top
fault was no compressor run
fault was traced to the relay on the board which is a bi-stable relay, therefore the voltage is only applied momentarily, so it is difficult to measure the voltage at the relay to determine if its failed
during the time I played with this board I found a test procedure that was aimed probably at production testing. both the boards in these units have 3 push buttons but only 1 is obviously accessible but the other 2 are there but you have to feel for them.
procedure
turn off unit at wall
press and hold centre and right hand button
turn on unit at wall
after a few seconds release buttonsif you now press the left hand button the relay will open and close press once “open” press again “close” and so on
it will revert to normal operation after about 30 secs or if you turn off and on again
at £100 a board or there abouts and in short supply this is a much cheaper option
hope this helps someone
January 28, 2014 at 10:32 am #309713RHrepairs
whirlpool azc6470 (produced in 2012) condensor dryer. fault f04 which means earthing fault, open thermostat or faulty pcb. if no earth fault or open thermostat change all three “hf115f relays on the board should solve the trick. must reset pcb afterwards to get the dryer operational
February 19, 2014 at 3:05 pm #309714iadom
Another variation on the Indesit/Hotpoint dishwasher pcb with no heat fault.
February 20, 2014 at 9:58 pm #309715eastlmark
Hotpoint/ Indesit dishwashers completely dead after power surge or power cut, later models/ heat pump style eg FDF780X but loads of others. ( the ones with the power pcb under the door).
Flat above a local pub, company came out to test the fire alrams and turned the power off and back on again, Dishwasher (although not on at the time) never worked again… nor did the Hotpoint Fridge Freezer.
Popped the board out to see hole in top of capacitor:the 10 ohm resistor alongside was open circuit and burned underneath- could not see that until I changed the cap. cap is 10uf 400v (RS 365 4751) once both replaced machine up and running.
now on to the fridge!February 20, 2014 at 10:04 pm #309716eastlmark
Hotpoint Fridge Freezer model FF4DXUK but loads of others, the type with a power pcb at the rear.
Appliance dead (no light even) after a power cut (see above post)
PCB had blown 10uf capacitor and 10 ohm resistor (3 watt wire wound in this case) open circuit. Replaced both and all now working fine.March 19, 2014 at 5:08 pm #309717DDA
I have a diplomat adp8234 PCB not heating. no power to the coil on the relay. any advice.
March 19, 2014 at 5:14 pm #309718iadom
This thread is purely for people to add repair tips etc. You should post a new question in the Trade Technical Thread. 😉
March 25, 2014 at 12:26 pm #309719Allsorts
On all of these errors/faults, check the capacitor C17 for domeing, remove & replace as necessary with 10v 680mf.
Indesit WIL, WIDL, IWM, IWME, possibly others too
Horizontal row of lights flashing
F09 Flash, OFF, OFF, Flash, eprom/setup errorHotpoint WF, WD, BWD and WT
Vertical row of lights flashing
F09 Flash, OFF, OFF, Flash, OFF, eprom/setup errorHotpoint WF, WD, BWD and WT & Indesit WIL, WIDL, IWM, IWME,
No power or lights litApril 7, 2014 at 7:22 pm #309720roy1
Hotpoint TCL dryers machine dead,change C20 10V 470uf & C17 10V 680uf capacitors
April 16, 2014 at 2:49 pm #309721Allsorts
Hotpoint WMA models (with the board behind the facia)
Fault – All lights flashing
Change capacitor C6 400v 10ufMay 29, 2014 at 12:01 pm #309722Hollytree_Technical
Whirlpool Washing Machines and Tumble Dryers
Fault: No Life
Cure: Replace the 3 ringed components
LNK304PN – RS part No: 525-4151
22 Ohm 3W Fusible resistor (yes I know that it is a 21 Ohm on the board but they are difficult to get and 22 Ohms works perfectly well).
470uH Inductor – RS Part No: 1910677Jem
