Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SIMPLE PCB REPAIR TIPS
- This topic has 82 replies, 41 voices, and was last updated 16 years, 2 months ago by
iadom.
May 29, 2014 at 1:38 pm #309723
ModeratorRe: SIMPLE PCB REPAIR TIPS
You need to make your pictures a bit smaller Jem, it’s causing the thread to only display half the screen, and that’s on my wide screen monitor.
I have shrunk it for you. 😉
July 10, 2014 at 4:36 pm #309724Profyaffle
ParticipantRe: SIMPLE PCB REPAIR TIPS
Electrolux Integrated Washing Machine E66, Heating Element always closed, cleaned board from carbon deposits and replaced 400v 10uf Capacitor C31. Job done
December 13, 2014 at 12:12 pm #309725dave-m
See attached a PDF version of this thread to add to your phone/teblet etc.
Regards
December 19, 2014 at 9:08 pm #309726iadom
As no one else has said it I must say a big thank to Dave for this excellent piece of work. 8) :tup:
December 19, 2014 at 11:00 pm #309727Andy jones
I concur
January 2, 2015 at 7:37 pm #309728twicknix
I’ve decided to take the plunge to repair the Indy board, a wixl model with all lights flashing. Instead of paying £30-40 to send it out to be repaired, naturally I would rather save money, do the repair myself and pocket the profit.
I found a blown capacitor and purchased some new ones from RS for £1 for a pack of 5 (680f 10v). Thinking that I am on the roll until I used my soldering iron that I had for a while (it’s quite new about 2 years old and only used about 4 times), turns out that it was not hot enough. Do I need to purchase the 50w soldering iron to do the job? If so, will I need to buy flux that can handle higher temperature?
The one I have may be unsuitable perhaps the one I have could be classed as a hobby iron.
Some help would be appreciated… BTW Happy New Year to you all.
Matt
January 3, 2015 at 12:41 pm #309729electrofix
25 watt iron is enough but you have to scrape off the varnish to be able to melt the solder
March 10, 2016 at 11:02 am #309730wilf
hoover /candy dryer relay its usually the capacitor that fails 0.22 uf 250v
wilf
May 16, 2016 at 8:39 am #309731neilsukwg
Following up on Dave-M post with the pdf file
I just dragged the pdf into my ebook converter and it looks great on a kindle paper white. :tup:
This free software converts pdfs into fully functioning ebooks to suit most readers
Search for Calibre by Kovad Goyal
March 29, 2017 at 7:21 pm #309732electrofix
Beko tumble dryer DCU8230
original symptoms blowing RCD
checked element found NTC to earth replaced element and still would not heat.
traced fault to resistor on board that had blown. nicked resistor off old Hotpoint board
fault curedDave
July 22, 2019 at 9:56 pm #309733electrofix
ModeratorI was asked to look at a Miele PW6080 LPED
This is a Miele professional machine and is situated in a nursing home laundry
Original fault is the machine would not start. There was no noise when the start button was pressedI removed the top of the machine and inspected the circuit board and found this
As you can see there is a burn mark between the orange relays
The part once removed looked like this
This component is actually a self-resetting fuse that feeds the door locking solenoid. If you look at the markings it gives a voltage (240v) plus L 016 which means 0.16 amps or 160ma
this is the replacement from RS
here is the new component in place
here is the board re installed in the machine
all working fine now very simple fix to a very expensive board
hope it helps someone as I cant see this component only being in these machines
June 22, 2020 at 10:29 pm #309734Hollytree_Technical
ParticipantBeko 2018/2019 onwards Washing Machine and Washer Dryer main board repair.
The common fault with these is a no life fault, this is usually caused by diode D7 being a dead short (image below).The origanol diode is an SR110 which is a 1A diode but it may be a good idea to use a higher rated diode like a SBYV27-150 (RS Part No: 629-5232) or equivalent.
Jem
August 15, 2020 at 6:07 pm #309735adv
Participantwhere would buy the diode from ? maplin these places all gone .. online take it ?
August 15, 2020 at 8:07 pm #309736electrofix
Moderatoradv wrote:where would buy the diode from ? maplin these places all gone .. online take it ?
rs components
farnell
and sometimes ebay and Amazonif you look Jem has put the rs part no he used
just has exactly the same fault on a Beko dryer and a tread mill. simple cheap fix, very happy customers
DaveJanuary 11, 2021 at 6:58 pm #309737washingmachinewoman
ParticipantFollowing on from the Beko no life issue, was told ideally you need to use a Shottky diode rather than RS part previously given. Here’s the one I have just used on a washer dryer:
https://uk.rs-online.com/web/p/rectifier-diodes-schottky-diodes/8129320/
