Smeg FAB32RNR not working at all!!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Smeg FAB32RNR not working at all!!
Viewing 14 posts - 31 through 44 (of 44 total)
  • #463684
    Specialist01269
    Specialist01269 wrote:Good picture, have you Metered the compressor yet ?. If you have, what were the readings ?. Could also be a shorted relay.
    Sorry, that should have read Meggered.
    #463685
    Smegy
    thanks replaced the relay so its not that, how do i check the compressor? can you send details i have checked continuity between all 3 pins and its ok.
    #463686
    well looking at the board its obvious you have a short circuit somewhere. Its not an earth fault otherwise it would trip your RCD and you don’t mention that.
    looking at the board (yellow arrow), this looks like a triac to switch one of the fridge components. It switches live to the red arrow line. to find the fault you have to find out where and what this goes to
    Smegy
    Hi Dave as explained this track goes to the black cable that runs down to the top pin on the compressor relay and goes into the top pin on the compressor. so could this be a faulty compressor? hi as mentioned in message 25 on page 2 the first board that blew tripped the RCD however the second did not.
    #463688
    blowing the rcd on a short circuit is random. sometimes they do sometimes they don’t.
    but if that goes to the compressor I would suspect it
    I assume you have already check the compressor components for damage if yes then its likely to be expensive to fix it
    Smegy
    Thanks, on the compressor the top pin is the offending black cable the bottom left pin brown positive and bottom right pin is blue neg. ok if i put a tester between the 2 bottom pins brown and blue i get 0 ohms, between bottom left and top (black) 18.0 ohms and between bottom right blue and top black 18.0 ohms. so i should be getting a reading between the 2 bottom pos and neg and im not, is this correct?
    #463690
    i would have expected the 2 lower pins to have some resistance but it not my area of expertise
    Specialist01269
    When you say 0 Ohms, do you mean the same reading that you get with your meter probes separated or when the probes are together ?.
    #463692
    Smegy
    Yes 0.00 the same as when the 2 probes are crossed touching each other.
    #463693
    Specialist01269
    So would appear that’s your short circuit, between the Live / Neutral input leads to the compressor. No wonder it went bang. Think it’s time for the scrap man, I’d hate to think what a replacement compressor & re – gas would set you back. Maybe more than a new unit.
    #463694
    Smegy
    140 pounds for smeg compressor whats the usual for the fitting and re-gas? its only 3 years old and didnt pay much for it
    #463695
    Specialist01269
    Depends on what area of the country your in to be honest, but probably about the same again or more. Is it really worth it for a 3 year old appliance ?. You’ve already bought the machine, the relay and the PCB. You don’t have a working PCB so that’s more money, at the end of the day it’s your money and choice. Personally I’d cut my losses and put it down to bad experience.
    #463696
    Smegy
    Will have a think.. have another PCB and relay, to buy a working one the same age between £400-£800 used and £1400-£1600 new so maybe worth it.
    #463697
    Specialist01269
    Good luck, please think carefully & maybe get some advice from a local specialist refrigeration engineer who can see and assess the machine properly.
