Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Strix to Diamond H ?????
- This topic has 21 replies, 5 voices, and was last updated 14 years, 2 months ago by
iadom.
January 25, 2012 at 4:08 pm #67576
ModeratorThis Strix is not listed on the downloadable pdf.
Strix OG1003
Creda Solarglo 48343.
Original wiring conns. on Strix regulator OG1003
Live to P1
Neutral to 4
It then has a double black and a single black wire on terminal 2 but the wiring diagram only shows a single connection to terminal 2 and no pilot light?????The leaflet that comes with the new Diamond H 40ER101C19 states that the wire from 4 should now be placed on 4A but there is no mention of the two separate wires, one double black and one single black that went to terminal 2. The Diamond H only has a single terminal 2 😕
Just to add, the enclosed leaflet doesn’t match up with the connections for the Diamond H 40ER101C1P listed in the pdf.
It shows Supply to 4A & P1 and load to 4A & 2. ????
January 25, 2012 at 5:38 pm #367840spimps
ParticipantRe: Strix to Diamond H ?????
Had the same a while ago but cant remember much other than having to use the theoretic appliance diagram combined with the new controls (which works differently internally to a strix) diagram to work out the circuit,starting from scratch really.
Not easy.
BGJanuary 25, 2012 at 8:11 pm #367841iadom
ModeratorRe: Strix to Diamond H ?????
A real headache, the theoretical diagram shows three connections to the regulator for both the Strix and Diamond H but the enclosed leaflet has four connectors on the new Diamond H in use.
It has to be something to do with the two separate black wires that originally went to 2 on the Strix, at least I think it has. 😕
January 25, 2012 at 9:03 pm #367842spimps
I follwed a recently ex hotponint engineer who gave up,I nearly did but decided to spend an extra hour or so as I don’t like being beaten.
I have a diagram of a solar glow you can have with strix controls if it is of any help,pm me if required.
I looked at how the new control actually switches internally then adapted the wiring to and from element to suit.
Cheers
BGJanuary 25, 2012 at 9:58 pm #367843iadom
Sadly I have to confess that I have already lost the ( £85) electronic controller on this, took out the RCD but not before it had goosed the timer unit. 🙁
I actually had two regulators to change on this thing, one was a like for like Diamond H, the other one is costing me dear.
I have both the theoretical wiring and the wiring connection diagrams in front of me.
The original Strix has got a single terminal 4 and a double terminals P1 & 2. The wiring connection chart shows a double connection to terminal 4 and a single one to terminal 2, exactly the opposite of what is actually in the damned thing. :rolls:
January 25, 2012 at 10:29 pm #367844spimps
It cost me a controller as I welded the internal contacts on the first controller,hot sweats and all that.
Was there a diagram with the new controller that shows the internals of the controller?January 25, 2012 at 10:40 pm #367845iadom
I’ll let you know when it arrives tomorrow. 😉
This is a scan of the leaflet, as you can see it makes no mention of the double connection to terminal 2 on original. The scribbles are mine BTW. 🙂
I am now going to go with,
Double live feed (two red ) to P1
Double neutral feed ( two black )to 4A
Load ( single red )to 4A
Load ( single black ) to 2Any thoughts?
January 25, 2012 at 11:07 pm #367846spimps
You could trace the load wires back to the element to ensure that is straightforward,test to see it is ok and then pilot could be piggy backed onto the appropiate load connection.
If you still have a problem I’ll pop back to the one I did a while ago and check the wiring.
These jobs come along now and again,juggles the grey matter!January 25, 2012 at 11:10 pm #367847iadom
There are no pilot lights for the rings on this though.
January 25, 2012 at 11:30 pm #367848spimps
iadom wrote:There are no pilot lights for the rings on this though.
Sorry,is it the neons on that showing which plate is still hot.
January 26, 2012 at 9:52 am #367849iadom
TBH I don’t think this model has that feature, will double check in the manual later.
January 26, 2012 at 5:41 pm #367850DentedPorsche
I think I’m losing something reading through the thread.
The strix, is it a single regulator having connections P1, 2 and 4 only?January 26, 2012 at 5:45 pm #367851iadom
Correct, I have it in front of me as I type.
One single terminal 4
One double terminal 2
One double terminal P1 ( only one of which was used ).It had live to P1, Neutral and load to 2 and load to 4.
What is confusing is that the wiring connection chart (page 19 in the manual ) shows 2 wiring connections to terminal 4 and only 1 to terminal 2, this is exactly the opposite of what this one has.
January 26, 2012 at 6:25 pm #367852DentedPorsche
OK, the original wiring diagram (which you no doubt have) shows double to 4 and single to 2. you have a double and a single on 2? Where does the double go off to?
I don’t see any hob hot lights so wondering where the extra wires are linked to.January 26, 2012 at 6:48 pm #367853iadom
Won’t know exactly until I go back tomorrow with new controller, I have allowed plenty of time. 😉
