Td Drum rubbing
Viewing 15 posts - 1 through 15 (of 24 total)
  • #28555
    mjhservices
    Does anyone know why Indesit / Creda / Hotpoint tumble dryer drums (after about 2 years) starts rubbing the back of the dryer. The drum seems to move from front to rear a small amount allowing this to happen. What is worn and needs replacing?
    Regards to everyone.
    #218812
    mowerman80
    Re: Td Drum rubbing
    I usually pack some washers on the drum shaft to push it forwards. This works for me.
    #218813
    mjhservices
    Re: Td Drum rubbing
    Thank you
    Mark
    #218814
    Re: Td Drum rubbing
    The drum has been completely modified, rounded off at the back , also the rear seal is thicker.
    cornwell40
    Re: Td Drum rubbing
    They’ve also put handles on the sides to help you get it in the skip 😉
    Tony C
    #218816
    hotpnt
    Re: Td Drum rubbing
    its the fluff that builds up around the fron seal/pads that pushes it back
    #218817
    helo_75
    if its 2 yrs old, it will need a drum
    is it vented or condenser?
    #218818
    bubs
    Re: Td Drum rubbing
    Because it’s rubbish.
    We sold one to a regular customer, it ripped an item of clothing on the first use due to the gap at the front.
    The fluff builds up due to the gap, it just dosn’t seal properly, also had a facia melt due to heat escaping from the front. Maybe best to put a washer on the drum before it’s sold 😯
    Graeme
    #218819
    mjhservices
    helo_75 wrote:if its 2 yrs old, it will need a drum
    Its a vented dryer
    Regards Mark
    #218820
    helo_75
    there shouldnt be a gap
    if there is, the felt seals missing, or you havent put it on the supports properly
    the drum part number is 1703662 btw
    you dont need to put a washer on the shaft if you use that drum, but i always fit a shaft kit , pt number 1703080, if the front pads are worn!!
    hope this helps
    #218821
    johnnyj
    Re: Td Drum rubbing
    If you are fitting the 1703662 drum to a back panel with square rear bearing the washer stays if to the tear drop back panel it doesnt.
    #218822
    helo_75
    nope… that aint true
    i fit 1-2 of these a week, and i never put a washer on, the whole idea of the new drum was to do away with the shaft kit
    i aint gettin into a debate about it, its always optional, of course
    #218823
    johnnyj
    Re: Td Drum rubbing
    I have in writing on a Q & R bulletin, i like you was throwing them away until this came out.
    #218824
    helo_75
    still cobblers
    #218825
    johnnyj
    Re: Td Drum rubbing
    Eh! who do you work for? i think i’ll give up helping on this site with t^ts like you about.
