Td Drum rubbing
Viewing 9 posts - 16 through 24 (of 24 total)
  • #218826
    Re: Td Drum rubbing
    Cool it, guys……….
    Simon46
    Re: Td Drum rubbing
    Got an IS60V to do tomorrow with snapped belt and snapped shaft. Am armed with thicker seals and pad conversion kit and washer. is this correct? Or should i replace the drum as well?
    S.
    #218828
    Re: Td Drum rubbing
    If I follow this correctly, the straight backed drum will try and foul the casing. The thicker sponges and washer are supposed to push the drum forward and increase the clearance.
    The new drum with the rolled-in edges has more clearance to start with.
    helo_75
    depends how old it is to be fair
    you need to be looking at the serial number
    if the rear of the drum is very close to the back panel, then really, its the best option
    trouble is, if you fit the shaft kit and belt, all you’ll get is ‘ it didnt scrape before you repaired it line’
    when you take the drum out, look around the panel and see if its been rubbing, and point it out to the customer, or ask them if its been noisy, previous to your visit, that’ll help
    good luck
    #218830
    helo_75 wrote:depends how old it is to be fair
    Or more to the point, how much the customer is prepared to spend. :rolls:
    helo_75
    exactly.. ive took to leaving the old sponge on, and using the new one and stick it to the areas where its been scrapin
    coarse, but it tends to work!!!
    #218832
    smartin
    Re: Td Drum rubbing
    ive found it all depends on how flat the floor is, a few pieces of cardboard here an there under feet and make sure its on a forwards tilt 😆 job done lol smartin
    #218833
    Simon46
    Re: Td Drum rubbing
    Had already had washer fitted so just fitted new shaft and belt. De lint city though. Filled carrier bag and hoover.
    S.
    #218834
    Re: Td Drum rubbing
    Was it as bad as this one, 😆 http://tinyurl.com/y7war7
