Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Td Drum rubbing
- This topic has 23 replies, 11 voices, and was last updated 18 years, 9 months ago by
mjhservices.
June 28, 2007 at 4:11 pm #28555
mjhservices
ParticipantDoes anyone know why Indesit / Creda / Hotpoint tumble dryer drums (after about 2 years) starts rubbing the back of the dryer. The drum seems to move from front to rear a small amount allowing this to happen. What is worn and needs replacing?
Regards to everyone.June 28, 2007 at 4:20 pm #218812mowerman80
ParticipantRe: Td Drum rubbing
I usually pack some washers on the drum shaft to push it forwards. This works for me.
June 28, 2007 at 4:52 pm #218813mjhservices
Thank you
Mark
June 28, 2007 at 6:03 pm #218814iadom
ModeratorRe: Td Drum rubbing
The drum has been completely modified, rounded off at the back , also the rear seal is thicker.
June 28, 2007 at 7:44 pm #218815cornwell40
They’ve also put handles on the sides to help you get it in the skip 😉
Tony C
June 28, 2007 at 7:45 pm #218816hotpnt
its the fluff that builds up around the fron seal/pads that pushes it back
June 28, 2007 at 8:29 pm #218817helo_75
Participantif its 2 yrs old, it will need a drum
is it vented or condenser?
June 28, 2007 at 11:22 pm #218818bubs
Because it’s rubbish.
We sold one to a regular customer, it ripped an item of clothing on the first use due to the gap at the front.
The fluff builds up due to the gap, it just dosn’t seal properly, also had a facia melt due to heat escaping from the front. Maybe best to put a washer on the drum before it’s sold 😯
GraemeJune 29, 2007 at 6:59 am #218819mjhservices
Participanthelo_75 wrote:if its 2 yrs old, it will need a drum
Its a vented dryer
Regards Mark
June 29, 2007 at 7:53 pm #218820helo_75
Participantthere shouldnt be a gap
if there is, the felt seals missing, or you havent put it on the supports properlythe drum part number is 1703662 btw
you dont need to put a washer on the shaft if you use that drum, but i always fit a shaft kit , pt number 1703080, if the front pads are worn!!
hope this helps
June 30, 2007 at 6:42 am #218821johnnyj
If you are fitting the 1703662 drum to a back panel with square rear bearing the washer stays if to the tear drop back panel it doesnt.
June 30, 2007 at 5:49 pm #218822helo_75
Participantnope… that aint true
i fit 1-2 of these a week, and i never put a washer on, the whole idea of the new drum was to do away with the shaft kit
i aint gettin into a debate about it, its always optional, of course
July 1, 2007 at 5:43 am #218823johnnyj
I have in writing on a Q & R bulletin, i like you was throwing them away until this came out.
July 1, 2007 at 6:27 pm #218824helo_75
Participantstill cobblers
July 1, 2007 at 6:43 pm #218825johnnyj
Eh! who do you work for? i think i’ll give up helping on this site with t^ts like you about.
