temperature not working right of domestic fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum temperature not working right of domestic fridge
Viewing 15 posts - 1 through 15 (of 48 total)
  • #103544
    Junk Yard
    Its an under the counter domestic fridge.
    Inside the fridge to the right middle is a control rotating switch with a light. The switch dose not power the fridge on at all 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the way to the left. But on the last 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}, there is a little clicking sound on it powers on and powers on full all the time where the temperature is around about -8C
    Any ideas where to start please?
    #493582
    first you say the temp in the fridge is -8 degrees and that cant be right or is it ?
    second you dont say which unit you have
    third temp need time to settle and you need to close the door and see what temp it ends up at by placing a thermometer in a glass of water to give an overall average temperature
    Junk Yard
    electrofix wrote:first you say the temp in the fridge is -8 degrees and that cant be right or is it ?
    yes that is right
    electrofix wrote:second you dont say which unit you have
    Kenwood
    Done all of that
    #493584
    well that sounds like either a board fault or the sensor
    on most fridges sensors are not replaceable and those that are often need you to dig a hole in the insulation and re foam it
    Kenwood is one of those makes where companies pay to use the name. probably imported by currys
    What model is it, as if there’s an audible click, it might be one of the few using a standard thermostat?
    Junk Yard
    kwatt wrote:What model is it,
    i dont know!
    #493587
    model number is often on a label inside the fridge hidden by the salad box
    Junk Yard
    electrofix wrote: model number is often on a label inside the fridge hidden by the salad box
    Found it!
    KUL55X17
    #493589
    yes K is correct its a simple stat so replacing it should cure it
    check yourself but it says it should be correct for your model
    https://www.espares.co.uk/fridge-thermostat/product.pl?pid=3253066
    Junk Yard
    electrofix wrote: yes K is correct its a simple stat so replacing it should cure it
    do you where the thermostat is located on the please?
    I have see thermostas sold on the net for around a fiver, are they no goo as junk from China?
    #493591
    it has to be the correct one for you unit or it wont fit
    the capillary tube has to be the correct length and the electrical connections have to be the same. if the chinese one fits the bill then its up to you
    the stat is behind the knob
    there will be a capillary tube that goes from there to where it needs to sense the temp
    Junk Yard
    electrofix wrote: it has to be the correct one for you unit or it wont fit
    Reading the above it sounded like they where all universal
    electrofix wrote:the stat is behind the knob
    Thanks! I have got it out now
    the sticker on it reads the following
    WDF25K-328-EX 1113209 170506-0212-1A
    Google brings up several shopping resaults
    WDF25K-328-EX 1113209 170506-0212-1A – Google Search
    Some are about a fiver but they are sites like AliExpress/ AliBaba and Temu
    While other ones range from 20-30 quid
    #493593
    Junk Yard
    electrofix wrote:there will be a capillary tube that goes from there to where it needs to sense the temp
    I dont understand what you mean? is this inside of the thermostat or outside of it?
    #493594
    Those codes, on Chinese stats like that, can be misleading. Stick with the manufacturer part number or you can run into issues. And no, they are not universal in many cases.
    https://www.ukwhitegoods.co.uk/help/fix-it-yourself/refrigeration-self-help/3658-fridge-and-freezer-thermostats
    Is a start on how they work and what we mean about phials etc.
    As a professional we go to the gen stat and only if the supplier says there is an alternative do we think about it
    if we get the gen then we have a 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance it will be ok. With anything else the percentages drop
